Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
Ez-ai Is Ready For Use Is Your Willing To Do A Bit Of Configuration Yourself
Ez-Ai Is Ready For Use Is Your Willing To Do A Bit Of Configuration Yourself
This thread contains the more recent information about EZ-AI. For information about EZ-AI visit https://www.ez-ai.net And visit the plugin page at https://www.ez-robot.com/EZ-Builder/Plugins/view/123
#57
Lol, with all of this I realized that I forgot RoboRealm and the avm module. You will want to get those and install them too.
#58
@d.cocharn, the php site does not work. the site does not have 5.6.5 it does have x.x.6 can you please have a look.
thank you.
#61
EZ-AI now has the ability to search through a database of over 20 million items to match UPC codes. I am using RoboRealm to look for these codes, and pass them back into ARC as a variable. Then I call EZ-AI \U [the upc code]
It will return the product description back to ARC in the $RobotAnswer variable.
There will be a minimal amount of setup that you will need to do to get this working. I will post a video and an install for 1.0.0.3 this weekend after testing on multiple items.
#62
Well, there is good news and some bad news on the upc module...
Good news, it is working. Bad news, the v4 camera isnt high enough definition to give good results. My laptop camera works good so, you might need to use a USB camera if you want to use this.
The other bad news is that even though the database that is being used for this has over 20 million items, it only detected 1 out of 5 items that I tried so I will shelve this for a bit and try to find a better conglomerate list of items for my area. This would probably work great in Europe. I will put a line in the config file to allow you to specify which database you want to hit. This one was good because it allowed me to use JSON to access it. I probably wont have time to look at it more until this weekend. I will wait to publish the exe with it until later on in the weekend.
#63
A new install video is building now. It involves installing all of the following components. It will be available to view this afternoon and will be posted. It is the same as the one done a couple of days ago with the exception of about 5 minutes of additional instruction starting at about 1:26:00. It will take 3 hours to upload it to youtube and probably 2 hours for them to process it.
EZ-Builder My sample project MSSQL server MySQL Program-o chatbot Python php IIS and configuring it to use php Roborealm Configuration of EZ-AI for your environment EZ-AI
It goes through the configuration of each program. There is a lot that makes EZ-AI work. There is a new zip file containing version 1.0.0.3 which includes the UPC Reader. There is a new install video including Roborealm and configuring your API key code for the UPC search module.
As mentioned earlier, the UPC reader through roborealm doesn't work well at all with the EZ-Robot V4 camera due to resolution of the camera. I have tested with my laptop camera and it works well.
If you have tried the install and need any help, please let me know. There really isnt any patch needed to go from 1.0.0.2 to 1.0.0.3. just copy the files with the latest date to your folder (except the ez-ai.config file). Make a change to your EZ-AI.Config file to include the added lines from the one that is in the zip and watch about the the new install video from 1:30:00 to about 1:32:35 to find out how to get your own API key code for the UPC search module.
