Brazil
What About We Send Him A Gift?
Hi friends Browsing around the instructables site I found this kid in Indonesia! His version of wal-e made of junk really impressed me.
https://www.instructables.com/id/Robot-real-size-LowCost-walle-made-from-water-pipe/
Specially because all the electronics are taken from old toys! I wrote him asking if he have heard about EZ-b. He said yes, but unfortunately have no money to buy one. So, I was wandering, with that kind of talent, what this kid would be able to do with an Ez-b in hands.. So, here is my proposition. Why don't we send him a board as a gift?! Mabe we could find 20 members that could contribute with, let's say, 15 dollars, and we could send him that? What you guys think? And, DJ, do you think the shop would be able to manage contributions and send him the kit? Just an idea... Greetings from Brazil!
Twitter
#161
This is amazing. So glad to have thrown in a bit for this. Awesome news Eric.
Indonesia
Thingiverse Google+ YouTube
#162
Hi Bongobong,:)
yes ... I am glad, finally get to see ez-board directly.
Thankyou Bongobong.
Eric Dirgahayu
Indonesia
#163
why my ez-cam always disable.. confused all is conected, and servo is work.
#164
@EricEZ. There are two halves to the camera board. carefully pull them apart and push them together to make sure they are fully connected. Also unplug and replug the cable on both ends, and if you have a multi-meter, check that there is continuity between the pin holes in the cable ends. One of my cameras had one of the wires that wasn't crimped well and just needed to be pushed into the connector a little further to work.
If it still doesn't work, contact EZ-Robot through the Contact Us page and select Warranty Replacement, and they will contact you about shipping a new camera (or may give additional troubleshooting steps). A few of the cameras came from the factory bad and needed to be replaced.
This is the main reason I created the account and ordered in your name, so that you would have easy warranty support if any of the parts were bad.
Indonesia
#165
Hallo Alan, how do you do?
I have long searched for you long time no seen.
all the steps I've tried and I've been using multy tester and everything is good, even the led blinking when turned on the camerapun at Ez-board. but when choosing a camera with that connection, disable camera News appears. and the program is good, sy try using webcam laptop and work. It's just that using a camera on the Ez-boar is always stated camere disable.
oke thankyou Alan.
Everything looks correct in your configuration. Only other thing to check before contacting EZ-Robot for warranty replacement is if you are running firewall software, you might want to try to disable it, or if it is sophisticated enough, add 192.168.1.1 port 24 as an exception.
Indonesia
#167
oke Alan, i will try, thankyou
#168
I think your camera's ip is missing a .23 at the end
