EZB Stress Test icon EZB Stress Test — Stress-tests EZ-B controllers (UART, ADC, voltage, temp, audio, digital I/O) to detect disconnects, corruption and stability issues. Try it →
Brazil
What About We Send Him A Gift?
Hi friends Browsing around the instructables site I found this kid in Indonesia! His version of wal-e made of junk really impressed me.
https://www.instructables.com/id/Robot-real-size-LowCost-walle-made-from-water-pipe/
Specially because all the electronics are taken from old toys! I wrote him asking if he have heard about EZ-b. He said yes, but unfortunately have no money to buy one. So, I was wandering, with that kind of talent, what this kid would be able to do with an Ez-b in hands.. So, here is my proposition. Why don't we send him a board as a gift?! Mabe we could find 20 members that could contribute with, let's say, 15 dollars, and we could send him that? What you guys think? And, DJ, do you think the shop would be able to manage contributions and send him the kit? Just an idea... Greetings from Brazil!
Indonesia
Thingiverse Google+ YouTube
#169
@A.Bautista, Whenever I star again and again even after I reset the same, so what a solution as well, thankyou:)
#170
Quote:
I think your camera's ip is missing a .23 at the end
No, that is incorrect. The :23 is for the EZB, not for the camera. Technically, the camera uses port 24, but the EZB:// takes care of that so it should just be the IP address: 192.168.1.1
What does the camera do when it tries to connect? There is a blue light that you can see (if in a case in a dark room). Is it blinking, not on at all or solid?
you might need to take the camera out of the case and make sure that the 2 camera boards are seated together good. Also disconnect and reconnect the cable.
#172
I had missed that you had already been asked to do this. I would contact ez-robot through the Contact Us link.
Indonesia
#173
Yes the blue led on the camera flashes when the ez-b is turned on, but the camera always disable, I already check all pin connections from 2 board camera and also the wire connection to the ez-board even I use multy tester to check it all OK, but when I clik start disable camera message appears.
Indonesia
#174
is still camera disable until now... tired
#175
Eric, did you use the Contact Us page to make a warranty claim? EZ-Robot will send a replacement if it doesn't wirk, but not from a forum post.
Indonesia
#176
Yeah I've been submitting Alan, and Aislinn has replied to my email, my reply and then send you a video about this issue. but haven't gotten a reply anything, so I am trying to open a discussion'
