Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Using Dragon Naturally Speaking With ARC
This has been brought up before is some threads, but has come up again recently. I promised that I would make a post about this so, here it goes...
There have been some posts where people have asked to be able to use Dragon Naturally Speaking (DNS) with ARC. To do this, there would have to be a separate application installed which would handle this unless there is a change to ARC itself to allow this to happen. To build an application outside of ARC to allow this would require some programming and a $2000.00 investment in the DNS developer software. To use this new tool, you would have to launch a separate application on your computer to handle speech recognition, which would pass the spoken text back to a variable in ARC. You would have to develop scripts in ARC to handle what to do with this spoken text. Another application would also need to be written that would allow the user to train DNS.
The idea of crowd funding has been brought up a few times in the past, but always in other threads that not everyone might have seen. I would like to suggest crowd funding of this idea again. It would be great if we could crowd fund the purchase of DNS Developer for EZ-Robot to add the ability to choose either DNS or Windows Speech Recognition engine directly within ARC. If that is not possible and there were enough people willing to crowd fund the purchase of DNS Developer, I would be willing to develop the 3rd party apps that could be used to handle what was described above.
This is to see how much interest there is in doing this. Please post if you would be interested in donating to this project or to donating to see if we can get this feature added directly into ARC.
One important thing to remember here. This path would only enable DNS for the applications above. It would not enable it on every application outside of these. In other words, you wouldn't have all of DNS on your machine, but only for use with ARC.
#89
Yeah, sounds good to me David. And thanks for the effort you and Alan are putting in to the research and updates.
Very greatful for your help indeed.:)
#90
Watson is another option for this. Speech to text rates are as follows.
First thousand minutes per month are FREE. Additional minutes are $0.02 per minute.
#91
I will get setup on both of these services. I need to figure out what I am going to use anyway so, this will be a good chance to test out both options.
#92
I'll be interested in seeing how Watson performs. 5 years ago I was evaluating platfirms that used IBM, Nuance, and Microsoft (not SAPI, an enterprise product they wound up selling). Nuance was far superior, but IBM has had 5 years to catch up since I saw them. In my more recent evaluation, none of the vendors used IBM or Microsoft. Most used Nuance.
I have just tested ibm and it worked better than Microsoft in dictation mode. It actually did pretty well. I have requested the dns cloud dev info but haven't gotten an email back yet. I do have to say that I was very impressed with how well watson stayed up with spoken text and you could see it changing other words already spoken based on the words new context of the words. Pretty cool.
#94
Hi,
i check this all youtube videos about watson.
Amazing!
Specialy the "Watson Jeopardy" ;-)
Do you know if Watson is also multilanguage?
Boris
