Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Non Existent Customer Support For A Newbie
Although my issue of the 300mv imbalanced battery issue is not a new topic, it happened to me after the first use only and there seems to be no customer service email link to address what is likely a defective battery or unit. I have followed all the recommendations but the charger keeps blinking 6 times red with one second pause. I only used the JD robot once to set it up and try a few moves, then as soon as it gave me the "battery running low warning" I shut it off, let it sit for and hour then tried to recharge and here I am. Robot sitting lifeless on my desk. I would prefer not to just return it to store but unless someone has a helpful thought, I don't even know how to get to Ez robot customer service.
#49
Thanks. Good to know for next battery.
hope it will arrive soon.
1 charge the batt before using the jd 2 wait 30 min after charging before using jd 3 wait 30 min before charging the batt
#52
Nomad 6R. Do you always need to wait 30 minutes before use after a fresh charge? Thanks
yes ,before and after
#54
the idea is to let the battery cool down. 30 minutes is a guideline. You can go less as long as the battery is cool.
With the battery hidden inside, I guess it's hard to tell if the battery is cool? How long have you guys been getting as operating time on a full charge (medium activity)? What should the expectation be? Would be nice to have option to have him run tethered and off battery for longer sessions
i saw time 40 min ones and the batt wasn empty
