Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Non Existent Customer Support For A Newbie
Although my issue of the 300mv imbalanced battery issue is not a new topic, it happened to me after the first use only and there seems to be no customer service email link to address what is likely a defective battery or unit. I have followed all the recommendations but the charger keeps blinking 6 times red with one second pause. I only used the JD robot once to set it up and try a few moves, then as soon as it gave me the "battery running low warning" I shut it off, let it sit for and hour then tried to recharge and here I am. Robot sitting lifeless on my desk. I would prefer not to just return it to store but unless someone has a helpful thought, I don't even know how to get to Ez robot customer service.
#57
Well Per Jason, in about 3-4 days I should hopefully start to ask you all more Robot related questions than battery anger. Can I make JD a battery Backpack he can carry around? :D:D:D
#58
You probably could, or maybe a front pack since he has all those wires coming out of his back. You can certainly get bigger Lithium 2S batteries, but even large ones are fairly lightweight. You'll need to make adjustments to the auto-positions to adjust his balance point so he doesn't fall over, and maybe add some scripting to the 4in1 sensor you bought to have recovery positions if it senses he is going over (there is a sample project that has him stand back up from a fall but I don't think there are any preventative samples yet).
there is a backpack to get for jd on xl robots.com.
#60
Alan, Haha, I'm clueless about what to do with the 4 in 1 sensor as of now, I just bought it because it sounded useful.. I really have no idea what to do with it initially when it arrives.
#61
With a JD, the best use is fall detection and recovery. It can detect whether JD is standing, on his back, front or side, and trigger a set of auto-position moves to stand up from there.
I am working on integrating mine into my Roli that has a Ping sensor on the front and adapting Rich's Ping-Roam script to use the compass rather than timed turns to change directions when it gets near an obstruction so it can wander around the house on its own.
Alan, this sounds very cool, but I guess that's way down the line from an understanding point of "how to do this on my part". Soon hopefully. I'm interested in the pandorabot thing first the the Cochran Robotics Ai next. My son loves trying to ask our Amazon Echo things it can't do (which is amazing what they are adding to it daily).
#63
Have you charged JD's battery with your other charger yet?
#64
Yes, but it never made it to the current voltage stage and the charged indicator did not light up after an hour or so, so I took it off as just out of precaution did not want to leave the battery charging overnight un-supervised. Charger is safe but you never know. I could try again tonight and upp the amps, I had charger running at 1A, should I try 1.5 or 2a charge?
