Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
Programing  Jd
I know this must be easy but I just can't find the right settings. I want JD to just see something moving and respond with speech. I also want JD to see a color and not get confused with movement and announce it. Can these both be run at the same time? Is there and activity to help with this movement recognition? Thanks All Ron
#57
WBS00001 Will the sleep instruction also work when doing the same activity with the new control line, shown here earlier from Richard to get the hands to go down after pointing. It seems the hands stay up for some reason.
How can new people to JD work if instructions are incorrect? AGAIN THANKS Ron
darticus
did you made this pose that jd does his arm up?if yes did you finich the pose with arm down.
#59
Nomad Using Richards control line, which is the new line used now, I think his arm stays down until JD sees a color than it goes up and stays up until JD sees another color than goes down and up to point and stays up again until another color is seen. This continues to repeat. Ron
New comers need help as we are trying to follow, out of date, and some none working info. after new updates are made.
darticus
am newbie to with very little practise. maybe you chould made a pose where jd raise his arm and lower his arm, and try then the color recognition.it works for me.
#61
@Nomad 6R newbie my butt:P... You have been around here for a couple of years dude... 2.5 years to be more precise... You joined the forum in June of 2013...
#62
I will try that. It might just be a sleep command and a stop command needed in the script lines. I am also new to this but we need to get correct methods. Doing this by trial and error will be somewhat aggravating and frustrating. I think we need more mini labs that will work all the aspects of JD. Than we can use what we learn to advance. I'm trying like everyone else. Once we get it, hang on! Thanks Ron
darticus
your jd looks real cool.
RR
2.5 years means nothing if you have to learn averything with one braincell.
haha:)
#64
Nomad I tried that line that they give us with the new JD download. This is the line Richard R had listed. This seems to be what everyone is using. By inserted the line sleep(3000) that WBS00001 added yesterday to the old line it makes the new line put its point down.
After going through all activities and all JD's I'm still looking for help in how things work. Example face recognition. Will check if there is a manual. Ron
