Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
@ nallycat. Where do get your "weldon 3 or 4 solvent "? I'm in Canada too.
Thanks.
@3dPrinterGuy. I use Weldon 3 and I get from PlasticWorld.ca around 15.00 a pint, but it goes a long way I also get the applicarion bottles with needle points. you use it the same as acetone on ABS. it fuses the plastic,. stronger then glue
Perfect, thanks Nallycat!
#52
Good evening all. I just have a couple of Really quick quick questions. Since i havent really been able to Start printing yet. I know everyone doesnt have the same Printers but asumming the settings See the same or at least similar. But i was wondering what should i have my Z settings at to be at the right height from the bed for printing. We have a 300x300x420 I3 Flusun 3D Printer. Also i Seen it on here but Cant find it where someone had built a Female Version of the inmoov ans since Wege making a Female Version to was wondering if we could get a Copy of the Female Parts Please and Thank u ist for our Home Automation Project Yours truly Paul
The distance from the print bed to the print nozzel is the thickness of a sheet of writing paper, but you have to make test runs as this thickness has more to do with the parts sticking to the print bed. does your printer have an auto leveling device or not? if not then read the instructions that come with the printer, this will give you a starting point for Z settings. I use a glass plate on the print bed and use hairspray on the glass. the printed parts easily remove after the glass cools. to test your part adhesion and to see if the print bed is level. print a brim on your part if the brim is thin in one area then adjust the print bed springs down to make that area print thicker. as for making a female version of Inmoov ,my advice to you is go to the Inmoov site and print inmoov as is, it is a complex build, and you should stick to the design until you gain experiance.:D
#54
It came with an Auto Level Sensor but ir didnt Seem to Let it go down Far enough so we Took it Off and put the z Sensor Switch back in Place to do it Manually
The Z sensor switch is for homing the Z axis you use it with the auto level sensor, which you should reinstall, you auto level the bed after which you home the machine and put a piece of writing paper between the nozzel and the print bed, if there is a large gap then loosen the screw on the Z axis micro switch and move it up a very small amount. then home the machine again and test with a piece of writing paper again until you feel drag on the paper when you put it between the print nozzel and the print bed.
#56
Good evening to all. I just wanted to say thanks to everyones help thus far. I'm excited and happy to announce. Since late Sunday morning around 8 am yes we were both all night and finally was able to get all the settings and the height just right and was able to do our real first print and we even reprintd that screw bolt and it turned out really nice. I wanted to share with you a side project of mine. I have always wanted to own my own on audio animatronic band since I and we can't afford our own. I decided to make my very own. With two singing cats and a dog. Here is the front, lower jaw and nose of one of the cats. The back is currently printing. Tell me what u guys think Paul
