Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
Microphone
— Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback.
greetings
yes I meant signal wire
what do i need to adjust in the script from dj? i have an alpha2 too and a metal robot. thanks
got it .i have 151 to 216 not alpha2 but the mettal robot
Patrick,
The script was just for testing. DJ is going to write a plugin based on the results. You don't need to do anything with the script and should not use it.
ah thanks alan.
Here: https://synthiam.com/redirect/legacy?table=plugin&id=240
Thanks so much DJ, can't wait to give it a try tonight
nick777
did you open your alpha 2.?
