Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
Myo Gesture Armband
— Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands.
greetings
Hi DJ,
Great news the script works, tested on ubtech servo's for alpha 2 and the Jimu robot set
thank you so much for taking the time to create a plugin for these servos I really appreciate it
Nick
Okay, can you try something for me? I’ll need to know the range. The documentation says it’s 120+position. The maximum value is 255.
So does that mean the position is between 120 and 255?
Can you remove the GetRandom() and change it to some values to find the max and min positions values for me?
both servos can move from 0 - 252
Interesting, so adding +120 to the desired position from the documentation is incorrect?
yes it appears so, I inputed the values directly into $data[4] anything above 253 actually comes up with an error
is there a tutorial how to do this what you did with the servo nick777 ?
Hi Nomad,
all I did is connect the positive and negative of the servo to D0 and the control wire to TX from uart0
ah i can use D23 too the control wire is the signal white wire ?too TX
