Germany
Control UBTech Alpha Servos With The Ez-b V4?
Control Ubtech Alpha Servos With The Ez-B V4?
Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
he's charging now.i try the walk later and post a video. you will need to adjust a lot.all standard jd have to go. and make your own.
Germany
#42
Ok thanks , i am excited to look the Video
here an update metal robot.you can choose for original jd movement do, you have to adjust everything.also calibrate everthing with the levers and horns, off.the problem with raising arms is solved,found that one. now hope i get the walking and sit down and so.
#44
The frame assigned to the STOP action in Auto Position has his arms raised.
Edit the frame that is assigned to the STOP action and move his arms into the position that you wish.
Locate the name of the frame that is assigned to STOP action...
Edit that frame...
hi dj
i found this .sofar ok but walking will be really diff.
#46
Andy/Nick anyone... can you try this? This is a quick script i created to test moving the servos based on the info you provided. I'll use this as an EZ-Script test before making it a plugin.
  1. Connect the servos to the UART #0 TX
  2. Power the servos with appropriate power
# Move Alpha 2 servo attempt using UART
# Connect signal of the Alpha 2 servo to UART #0 TX port
# Moves the servo set for ID #0
DefineArray($data, 10)
$data[0] = 0xfa
$data[1] = 0xaf
$data[2] = 0x00 # servo ID 0
$data[3] = 0x01 # command: goto
$data[4] = 120  # Position: We will modify this value in the loop
$data[5] = 100  # MS/20 duration? no idea
$data[6] = 0x00
$data[7] = 0x01
$data[8] = 0    # we calculate checksum in the loop
$data[9] = 0xed
UartInit(0, 0, 115200)
:loop
# some random position to try moving to
$data[4] = 120 + getrandom(10, 100)
print("Moving to position " + $data[4])
# calculate checksum
$data[8] = ($data[2] + $data[3] + $data[4] + $data[5] + $data[6] + $data[7]) % 256
UartWriteBinary(0, 0, $data)
# pause for 2 seconds between movements
sleep(2000)
goto(loop)
#47
Great robot!
I love the work you're doing and the community's help with your project.
Scott
Hi DJ,
I should be able to test out the script tonight, sorry for the late reply just got back from holidays.
Nick
