Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Germany
Control UBTech Alpha Servos With The Ez-b V4?
Control Ubtech Alpha Servos With The Ez-B V4?
Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
#33
Quote:
hey one question yet these servos run but without problems with the Ez-b V4?
They should. From what I could find, they are 7.4v, so OK to use a 2s LiPo battery (recommended for EZ-B) to drive them directly from an EZ-B without worrying about alternate power or voltage regulators.
i tested these servo's today.wiht a lipo 1300 mah you do some 12 minites then your batt is empty.if you want to build a complete robot you need a batt, aleast 2500 mah
#37
nomad - what servos are those? 12 minutes is not very long!
hi dj sorry late respond.i bouth this on ebay.here is the link.
servo robot
i forgot the robot has a 2800 mah batt.
Germany
#40
Hello Nomad I'm just building my EZb in an almost same robot. Do you have more videos? Can you let him go? If so, can I get the script?
