Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
Smart Variable Watcher
— Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length
greetings
Nick, can you try the plugin with only one V port selected. Meaning, only attempt to move one servo. And, use this script...
And tell me if the servo moves using the plugin and this script - thanks!
Also - update to the latest ubtech plugin in ARC please. Thanks!
Plugin link: https://synthiam.com/redirect/legacy?table=plugin&id=240
@Nick - any word on the updated plugin?
Hi DJ,
Sorry no, been away from home on business since last Thursday, back Friday will be able to test then.
I’d be more than happy to send you a Jimu robot kit with servo’s from amazon if it would make things easier ? Just email me a shipping address
Either way I’ll do the tests you’ve asked for by Friday
Nick
Let’s try the plugin first. I had a few mistakes that I didn’t notice when I first published it. Thanks for the offer though.
Hey Nick, how did the plugin work for you?
Hi DJ,
The plugin works great, had problems initially with it crashing on startup but this seems to be resolved after a windows reload
tested so far with 3 different types of ubtech servos chained together, working really well.
I know I'm pushing my luck but a feature request would be to add an option to read a set of linked servos and get it to automatically generate a frame in the auto-position plugin, my reason for requesting this is to make it easier for younger kids to be able to use it to make robot skits.
Thanks again, now I just to give the Alpha 2 an EZB brain transplant
Nick
Great to hear!
