Shortcut Creator icon Shortcut Creator — Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Germany
Control UBTech Alpha Servos With The Ez-b V4?
Control Ubtech Alpha Servos With The Ez-B V4?
Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
Germany
Does the Alpha 1 Series PC communication proto continue to help?
i didn get any contact with UB on there site or FB or skype.they dont just respond.
No, that is for communicating with the controller, not the servos.
Germany
I have also ubtech times now hopefully they have an answer. Or do you have any idea Dj Sures?
Germany
Which data do we need exactly?
Serial protocol for the servos.
Germany
#15
And that is not enough? Sorry for the questions I'm newbie
No, that is not enough. Most servos use a standard communication method called PWM (see hte servo tutorial in the learn section of the web site). These are custom servos that use Serial communication, and probably a proprietary instruction set. Dynamixel servos also do this, but they publish the instruction set so DJ was able to write a plugin. For anyone to write a plugin for these, we need the data rate and other connection properties, and the instructions and responses of the communication protocol.
Very unlikely UB is going to provide this.
