MP3 Trigger icon MP3 Trigger — Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party. Try it →
#153
Will check more and get back. Gotta get info on using the Autopositioner control. Ron
#154
Thanks DJ I will check things more today. Good to hear I might still get this going. Ron
#155
Turned on my computer and ran ARC. Turned on JD and hit connect to JZB on my wifi. Than hit connect to the right of my screen. Would not connect seems like a red and blue light going on. Shut down program got to go online than opened ARC again. Turned on JD again and erratic red and blue lights. Blue blinking than goes to solid, red flashing pulsing. Eventually solid blue light and connected. Will start blinking a red flashing light and jams. Ron
#156
@darticus
I'm going to make the assumption here that you are using the JD Example Project and you already have an Autopositioner in it.
The Auto Position control is on the upper right. On that control is a gear icon on the upper left. Click it. That will bring up the setup window. It will already be set to the "Frames" tab.
On the upper right is a check box labeled "Realtime Update" in red letters. Make sure that box is unchecked for now. Below that check box are 3 buttons, and below the last button ( "Remove Frame" ) is a rectangular box with the names of various frames. From that list choose "Calibrate."
Now, be careful because JD will go to the calibrate position when you click "Transition To." It should transition to that position ar a reasonable speed, but I have found that if this the first time you click the transition button, it will tend to jump to the new position. Anyway, click "Transition To" button now.
Once all this is done, click the box labeled "Realtime Update".
From this point on, whatever changes you make in this frame will cause JD to immediately move accordingly.
All the control boxes should have the number 90 in them. Find the one which corresponds to one of the servos you mentioned in your previous post. Move the mouse cursor over that box and click and hold the left mouse button. As you move the mouse up and down the servo should move at the same time. You may have to hold JD up with your other hand to allow the servo the freedom to move.
Run the number in the box all the way down to 1 (not 0) and observe the servo to see if it goes nearly all the way it physically can as you do so. There should be some movement, even if slight, all the way. If it stops moving significantly before you get to 1, there is a problem. For example, if you get down to 10 and, as you keep going down, the servo does not move, something is wrong.
Do the same for the other direction by going up to the max of 180. Again, as you near 180 be sure to watch to see the servo moves some even as you get close to 180.
Do the same for the other servo.
Since you were saying one went farther than the other, this test will allow you to see if they are both going full distance. If not there can be several reasons why not.
  1. The servo lever is way off. This would show up as the servo lever not making it to it's max or min position in one direction and going to it's max or min too soon in the other.
  2. somewhere in the initialization script (or a script you are running) the travel of the servo has been limited by the SetServoMin or SetServoMax (or both) script instructions.
  3. The servo is simply physically or electronically defective.
Once you are done with doing whatever you need to do, be sure to set the servo control boxes you changed back to 90.
Hopefully these directions will help you to determine which problem you have.
#157
@DJ_Sures Speaking of the bottom covers of the ankle servo, I was wondering if those covers (or the servos themselves) could be purchased separately?
I could have used those covers recently. Would have saved me from severely modifying the bottom covers (White part) on some lever servos to work for a Meccanoid. That, or just ordering 8 of the ankle servos and using them directly instead. Too late for me now, but I know of at least one other person who plans to do the same thing.
#158
WBS00001 Thanks for all that info and I will try to use it later. I disconnected all the plugs in the back of JD and ran ARC. Everything connected fine and no loose connection at the deans plug this way. I than installed all the servos etc. again to see if I put them in the wrong places. I ran ARC and connected to JD. I hit bow and he did it but jerking with each move delaying as he moved. I tried again and the same thing. Tried to get him to do fly and he jerked into a flight position stopped stood there bent over black screen came up saying disconnected no sound from JD and program locked up. Had to shut down computer to get out. How long does the battery in JD work for. Recharging and trying again. Thanks all Ron
#159
MIRACLE I THINK! MY wife mentioned the wireless items in the house. Like phone, cable, speakers, etc. Unplugged all and he seems to be working. Now a little fine tune and maybe good to go. Gonna miss my TV etc. but shoot JD is happy! I still wanna check the Auto Position thing. As soon as I plug the wireless TV cable in the red light in JD starts to glow on and off and he gets jerky in his applications like bow. Thanks all Ron
#160
I am at work, so I can't check, but I am pretty sure you can change the default WiFi channel in the web interface for AP mode. It is probably set to Auto, but very likely defaulting to channel 1. Try setting it to channel 6 or 11 and see if the issue clears up.
Changing to Client mode can also help a great deal (even though you are then sharing the same channel with the other devices, you are sharing it on the same WLAN so there is less contention).
