PLEASE NOTE: THIS GUIDE IS OUTDATED. BADLY. (remind me later to fix this and spiff it up a bit, please)
So, you finally have your EZ-B v4. You love it already, and you're ready to hook this baby up to some sort of Dynamixel powered creation. You go to plug everything in, and - wait. You have no idea how to set those Dynamixels up.
Well, I do, and I'll show you how.
SECTION 1: GETTING TO KNOW DYNAMIXELS
Dynamixels are intelligent servos that can track not only position, but temperature, speed, and load. The servo can automagically shut itself of incase of a failure. These servos are also incredibly strong. But there's one feature in particular that is useful, but at the same time a little hard to wrap your head around. In this section, we will cover daisy chaining and other features of the AX-12A Dynamixel; however, most of the servos in the Dynamixel family work exactly alike, so this guide can help you with most models.
On the back of all of your Dynamixels, you will notice a couple things. A place for a bolt, a light, two wire ports, and the ID. Lets go over all of them so you know what they do:
Light - Blinks once when turning on. If the light is flashing, there is a failure of some sort.
Screw hole - Allows you to attach the Dynamixel to a bracket.
Wire ports - Allows you to connect to other Dynamixels, in a long strand of servos, both to and from other Dynamixels. This means both ports work the same way, which means it doesn't matter which side is plugged in. (see image below)
ID - What the EZ-B and ARC address the Dynamixel as.
PART 2: CONNECTING YOUR DYNAMIXELS TO THE EZ-B
All Dynamixels must plug into port D5 in order to properly work. This means that all of your Dynamixels must plug into one port. If you have more than one strand of connectable Dynamixels, you will have to use a Dynamixel splitter hub, like this one here:
You can either run a cable to the EZ-B via a power base or via the powered splitter. I advise that you use only one, as using both at once can brown out the EZ-B.
Q: So, now that that's done, what power supply do I use? Mains or a battery pack?
A: Both will work just fine. Just make sure you have an adequate power supply at around 10v.
"But wait!" you scream. "Dynamixels can run at 9v-12v! Why 10v?"
Because voltage is gradually lost over time depending on how many servos you're running at once, as well as when the EZ-B is powered on. The more servos you have, the higher you should up your voltage to get a steady 10v overall.
So, if you have power running to the EZ-B, Dynamixels set up to port D5 (as well as the optional splitter) you should have something resembling this:
Now that you're powered on, lets move into ARC and get your Dynamixels running.
PART 3: OPERATING THE DYNAMIXELS WITH ARC
Connect to your EZ-B as usual (We won't be covering connections in this guide). Bring up a servo control panel and go to the servo configuration screen as shown below.
Click the Dynamixel box and scroll down until you see the ID of the Dynamixel you want to move (the ID on the back of the servo). In this demonstration, we'll be selecting Dynamixel AX18.
Select it and save the configuration. Congrats, you just set up your first Dynamixel in ARC! It should operate just like a normal servo. This applies to all servo control functions.
PART 4 (EXTRA): ASSIGNING A NEW ID TO BLANK SERVOS
When you buy a Dynamixel that doesn't come in the kit, the ID sticker will sometimes be blank, which means it hasn't be assigned a "real" ID. However, a tool in ARC can give Dynamixels a new ID.
First, open up the Dynamixel Config. control in ARC. You should see something similar to this:
All blank servos are assigned ID 1. If you have a dynamixel with the ID 1 already, remove it before you proceed. Simply choose the new ID you want (in this case, AX18) and press execute. ARC will assign it a new ID. That's it, you're done! You can also write the ID on the blank tag if so desired.
GUIDE LAST UPDATED: 12/9/2014
sudo can you ad a clear pic how the wire is connected from the hub to the ezbv4.
my camera is dead, so let me talk you through this with the picture above.
Set down your robot so the EZ-B symbol is facing AWAY from you, like in the photo. Then find port D5. Now, plug in your dynamixel wire with the bumpy end facing TOWARDS you.
I'll be able to clarify this in the guide with a close up photo tomorrow
sudo
i dont have parts yet to start.i just ordered two hubs . in few weeks i can order extra ezbv4 for this. then later some servo's ax-12A am making a pic now will upload in few sec.
yes, that is the side that should be facing you. Just plug it in and try moving a arm to get the hang of it, dynamixels are a little tricky to understand at first. It's a good idea to get used to how they work with the EZ-B.
also - remember to turn down the speed a bit in the legs, or you'll burn out a bunch of servos. Take it from me, i've basically had to buy half of a new bioloid to replace my servos stress
sudo i know the feeling.my first atemp building a bioloid i burn 10 servo's. because i didn know any off robots and the seller swithed one off the wires, dilibertly.in two weeks i by two servo's to practise whit.
these are my boys.A-type whit turning head/C-type turning waist/comp whit, turning AX-S1
Whoop! Just forgot - the EZ-B doesn't support gyros yet, so you may want to copy JD for a while (with his giant feet) until that mystical gyro is released
sudo
i bin working on the kd robot.so i have plenty off time.
Aww, you replaced the hand drawing with real pics. However this really looks great! Nice work!
@nomad18.08, Are those your robots in the vid you posted? Did you build and program them?
