Dialogflow icon Dialogflow — Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control. Try it →
Sudo's Guide To Dynamixels
PLEASE NOTE: THIS GUIDE IS OUTDATED. BADLY. (remind me later to fix this and spiff it up a bit, please)
So, you finally have your EZ-B v4. You love it already, and you're ready to hook this baby up to some sort of Dynamixel powered creation. You go to plug everything in, and - wait. You have no idea how to set those Dynamixels up.
Well, I do, and I'll show you how.
SECTION 1: GETTING TO KNOW DYNAMIXELS
Dynamixels are intelligent servos that can track not only position, but temperature, speed, and load. The servo can automagically shut itself of incase of a failure. These servos are also incredibly strong. But there's one feature in particular that is useful, but at the same time a little hard to wrap your head around. In this section, we will cover daisy chaining and other features of the AX-12A Dynamixel; however, most of the servos in the Dynamixel family work exactly alike, so this guide can help you with most models.
On the back of all of your Dynamixels, you will notice a couple things. A place for a bolt, a light, two wire ports, and the ID. Lets go over all of them so you know what they do:
Light - Blinks once when turning on. If the light is flashing, there is a failure of some sort.
Screw hole - Allows you to attach the Dynamixel to a bracket.
Wire ports - Allows you to connect to other Dynamixels, in a long strand of servos, both to and from other Dynamixels. This means both ports work the same way, which means it doesn't matter which side is plugged in. (see image below)
ID - What the EZ-B and ARC address the Dynamixel as.
PART 2: CONNECTING YOUR DYNAMIXELS TO THE EZ-B
All Dynamixels must plug into port D5 in order to properly work. This means that all of your Dynamixels must plug into one port. If you have more than one strand of connectable Dynamixels, you will have to use a Dynamixel splitter hub, like this one here:
You can either run a cable to the EZ-B via a power base or via the powered splitter. I advise that you use only one, as using both at once can brown out the EZ-B.
Q: So, now that that's done, what power supply do I use? Mains or a battery pack?
A: Both will work just fine. Just make sure you have an adequate power supply at around 10v.
"But wait!" you scream. "Dynamixels can run at 9v-12v! Why 10v?"
Because voltage is gradually lost over time depending on how many servos you're running at once, as well as when the EZ-B is powered on. The more servos you have, the higher you should up your voltage to get a steady 10v overall.
So, if you have power running to the EZ-B, Dynamixels set up to port D5 (as well as the optional splitter) you should have something resembling this:
Now that you're powered on, lets move into ARC and get your Dynamixels running.
PART 3: OPERATING THE DYNAMIXELS WITH ARC
Connect to your EZ-B as usual (We won't be covering connections in this guide). Bring up a servo control panel and go to the servo configuration screen as shown below.
Click the Dynamixel box and scroll down until you see the ID of the Dynamixel you want to move (the ID on the back of the servo). In this demonstration, we'll be selecting Dynamixel AX18.
Select it and save the configuration. Congrats, you just set up your first Dynamixel in ARC! It should operate just like a normal servo. This applies to all servo control functions.
PART 4 (EXTRA): ASSIGNING A NEW ID TO BLANK SERVOS
When you buy a Dynamixel that doesn't come in the kit, the ID sticker will sometimes be blank, which means it hasn't be assigned a "real" ID. However, a tool in ARC can give Dynamixels a new ID.
First, open up the Dynamixel Config. control in ARC. You should see something similar to this:
All blank servos are assigned ID 1. If you have a dynamixel with the ID 1 already, remove it before you proceed. Simply choose the new ID you want (in this case, AX18) and press execute. ARC will assign it a new ID. That's it, you're done! You can also write the ID on the blank tag if so desired.
GUIDE LAST UPDATED: 12/9/2014
dave
yes i build a total off six bioloids thats alot off screws. the programming is standard,but i made some moves whit the heads and waist.
#26
@Dave thanks! I think the actual pictures make it easier for people completely unfamiliar with Dynamixels or robotics in general to take full advantage of these wonderful servos for a project. Thats why I made this guide, after all.:D If you have any questions you can ask in the thread so I can add it to the guide, it always seems that I forget something fairly important and then someone has to come and wait for me to answer blush
sudo
ez&bioloid has alot desame.you build lots off diff robot.you can by parts separt.
this one i made and had to redo all moves in motion.
Nice collection of humanoids you have there @nomad18.08 ! Did you win the Lotto? Robots are such an expensive hobby! BTW, have you finished building the Japanese one that comes monthly in a magazine (can't remember the name of it)?
I have a little Darwin Mini which uses the Dynamixel XL-320 servos. It can be controlled by a phone and do some amazing acrobatics. Unfortunately 4 servos have already failed after very little use. They are now making them with metal pinion gears, so hopefully that solves the problem! Unfortunately they only replace them as they fail.
Eventually, when the servo issue is resolved, I will try to get it to work with an EZ-B V4. I did see a picture of a Darwin Mini on this Site with the words "Coming to Ez-B V4" Perhaps DJ is already playing with one?
#29
Oh, I think those servos are already supported. @Dave said something about one of the protocols containing the XL's. Maybe try one out for us and see what happens?:D
tony
the japanese robot is robi.waiting for new wires.it had a design fault in the upperlegs.and no i dont have lots off money,just i dont have a car or motorbike, dont go out.i life very simpel.also i have alot to thank my room mate els , i wouldn be able to by anything.
sudo am looking forwart to see your idea bioloid on ezbv4 whit voice lester.
#31
He works pretty well already, he just has a few issues with balance which I hope to temporarily remedy by making interchangeable velcro feet.
sudo
did you ever try the balance task&motion off bioloid?i didn. i did see you mount bioloids feet at the tip?
