Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
New Sensor I Found
New Sensor I Found
Well its new to me. I can see it now. "Dave, there seems to be an approaching storm. It's time to stop our soccer game and get inside":D eBay Link, Datasheet Link
Franklin Lightning Sensor provides early warning indication of lightning storm activity within a 40km range
  • Provides distance estimation to the head of the storm
  • Detects both cloud-to-ground and intra-cloud (cloud-to-cloud) ashes
  • Intelligent algorithm provides for false disturber rejection
  • Programmable detection levels enable threshold setting for optimal con gurability
  • SPI and I2C interface is used for control and register reading
  • Automatic antenna tuning
  • Supply voltage range 2.4 to 5.5V
  • Power-down, listening and active mode
Here is another one for motion detection for up to 20 meters. eek Microwave Doppler Radar Motion Sensor
Datasheet is here: https://www.apollounion.com/en/down.asp?filename=Upload/DownFiles/HB100.pdf
Edit: see post #6 for better one.
UPDATE: Here is another lightning detector that popped up. eBay Link
#17
That is perfect ! Thanls for locating it.
That was a custom job that guy made. Here is one made with an E-Cig you can make.
#21
Troy, I've enjoyed your finds. Please don't keep them coming when you run across something! This latest one is a good one!
#22
I check the same handful of websites from time to time. Ebay, pololu, parallax, trossenrobotics, robotshop, sparkfun, servocity, banebots, robotstore, robotmarketplace, vexrobotics, superdroidrobots, dfrobot, etc. Sometimes there's something that stands out to me as a new idea or a part for sale. If someone has a new link to add, please add it here.
