Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
New Sensor I Found
New Sensor I Found
Well its new to me. I can see it now. "Dave, there seems to be an approaching storm. It's time to stop our soccer game and get inside":D eBay Link, Datasheet Link
Franklin Lightning Sensor provides early warning indication of lightning storm activity within a 40km range
  • Provides distance estimation to the head of the storm
  • Detects both cloud-to-ground and intra-cloud (cloud-to-cloud) ashes
  • Intelligent algorithm provides for false disturber rejection
  • Programmable detection levels enable threshold setting for optimal con gurability
  • SPI and I2C interface is used for control and register reading
  • Automatic antenna tuning
  • Supply voltage range 2.4 to 5.5V
  • Power-down, listening and active mode
Here is another one for motion detection for up to 20 meters. eek Microwave Doppler Radar Motion Sensor
Datasheet is here: https://www.apollounion.com/en/down.asp?filename=Upload/DownFiles/HB100.pdf
Edit: see post #6 for better one.
UPDATE: Here is another lightning detector that popped up. eBay Link
#49
The dust sensor mentioned a little bit ago would be funny to use.
"I'm getting all dusty!" says wall-e.
#50
Here is something useful if you have a salt water fish tank that you need to monitor the water level with an EZB. eTape Chemical Liquid Level Sensor From the websight
Key Features: Rated for chemical, petroleum, and food-safe applications Crimpflex male pins easily connect to microcontroller projects Reference resistor pins allow for optional temperature compensation Protected vent hole to equilibrate with atmospheric pressure
Application Ideas: Evaporation rate monitor Aquaculture projects Industrial mixing control systems
