HTTP Server (Custom) icon HTTP Server (Custom) — HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot. Try it →
Unable To Open Project
I just tried to open my project and I get a Windows error box on the screen saying "Unable to load project. Object reference not set to an instance of an object". So then I tried to load it from the Cloud and I get the same thing. I have a gazillion hours in my project and I can't imagine it all for not.
#33
I did as you instructed and there are no instances of ezb. I have always connected in client mode. I have never been able to connect in AP mode.
#34
In order to configure client mode, you must have been able to access the web server therefore working in AP Mode. To clarify, the default mode for the EZB is AP Mode.
Have you always used that computer or is there another computer that you connected to for the configuration change on the EZB?
#35
just a idea...
With my desktop wired and wireless connections my subnet is 192.168.1.1-255. i was unable to connect too.
but tried on laptop only connect wireless to connect and set my v4. it works fine.
after that able to connect with desktop after v4 was on my subnet.
j
:D
#36
DJ, I have always used that computer for EZ-B.
#37
You must have initially (at some point) connected to your EZB in WP mode because that is how they are shipped... And you can't connect in client mode until you first connect your PC to your EZB in WP mode.... Then, from WP mode you can then access the ezb web server in order to put your EZB in Client mode...
#38
Can you use/find another computer to try and connect to your ezb? All you need to do is use the other PC to connect in wp mode then to set the ezb in client mode. After that you should be able to now go back to using the pc that was giving you the connection problems (because now the ezb4 would be back in client mode)
#39
Thanks Richard, I have tried two different computers. Going to try my wife's laptop next. To answer your question my first connection was on a friends laptop which happened to be here the day v4 came. I couldn't connect with my computers then either.
#40
Bookmaker, you always used your friends computer? But your friends computer worked the first day? If you can clarify with specifics, tbay would help. We want to get you up and running:)
