NMS Example icon NMS Example — Example NMS Level #1 navigation skill showing subscription to combined scan+location data, displaying position and scan info; source code included. Try it →
Talking Servo / Inmoov Mouth Closed After Sentence
Hello,
i have a problem with my inmoov.
I add a "talking servo" i adjust the servo - everything is fine i have only one problem:
After a sentence the inmoov leave is mouth open. Nevermind how long or short the sentence is... the mouth is in the end still open.
I cant find any option to say after a sentence got to this servo postion.
Thanx for help.
Boris
#25
Yeah, looks like the servo is reversed:)
Mouth is opening when it should be closing...
and its sayezb("goodmorning") not say(" goodmorning")
#27
Hmmm, that's strange that the Invert Direction doesn't do anything. Maybe, write down all your settings and delete the Talk servo control and then add it again and start new with it. It shouldn't matter where the power is coming from I have mine set up the same way as you.
#28
PS:
i made a new project- only with the talking servo!
I plugged 1x Towardpro MG996 and this servo turn to the left , if a sentence is spoken. ( Invert not work!) I checked with 2 diffrent MG996 - all do the same
i plugged 1x Hitec HSB-9380 and this servo turn to the right, if a sentence is spoken (Invert also not works) I checked with 2 diffrent HSB-9380 - all do the same
So i found out, that diffrent servos are turning in diffrent positions.
One to the left - one to the right!
But on all no "Invert Function" will work!
So i need that my HSB9380 is turning to the left and not to the right! But how?
Boris
#29
@nomad... he is using "talk servo" which is a new text to speech control ... it is irrelevant that he uses say, saywait, sayezb, sayezbwait... Doesn't matter which one he uses
richard r
ah thanks for telling
#31
Ok, that is strange.... how is it possible that the servo is working backwards? With my inMoov 50=closed mouth and 115=open mouth... @Boris 180 is open mouth for you?
#32
When you first installed your Jaw servo did you set it to 90 degrees? If you didn't that may be your problem - it might be maxing out so it can't "invert"?
