Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
#33
@nomad... Can you post a picture of your JD connected to ARC with all the servos set at 90?....
well then i have a problem.when i open ARC he shows the init script. i click open and connect jd ,he doesn take the pose off the init.
#35
Just set all JDs servos to 90 (no offsets) and let us see what he looks like when you connect to him in ARC....
#36
  1. Are you using the latest version of ARC and the latest JD example project?
  2. Have you modified the JD project in any way?
@Richard, the brackets are preinstalled (hence the requirement for calibration).
ok i make a pic connected to pc.
the brackets where on the servo allreddy mounted. and my exsperiance tell ,do the offset whithout the brackets.
#38
@Rich... Thanks for that.... Then I guess Nomad is just not using the software correctly?.... I don't have anything else to suggest @Nomad, sorry....
#39
Leave the brackets.
Do the offset on an assembled robot
rr i like anest answers.am uploading a video. for the first time the ARC gifs an error.cant fint init pose.
