does anyone has done the offset from jd? and second howmany degrees is jd neck ?
— Edited
9 Participants
Sharp IR Radar
— Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel
@d.cochran... Again, kudos to you for your patience and effort... I see sainthood in your future dude... Patrick claims he forgets everything he learns so bottom line is, what is @Nomad to do when you stop holding his hand?
Once the robot is built and working as it should be, he will be able to use the ARC software to do what he wants to do. He will be able to share his project and get help. The parts that I am helping him with are his network and the calibration of JD. Help isn't really able to be given in these areas as easily as in ARC. To me, the wonderful thing about ARC is this ability to share and help others pretty easily.
I am putting together JD tonight before I call Patrick in the morning. This will help me to recognize what is wrong more quickly. I am interested in this also because I will be showing my students JD and Six on Monday in the box, and they will be putting them together. This will also help me in the long run.
rich&rr
first i wanna appolegize,i didn understand what you where asking. now i do,prefering the tutorials.well it looks like i have a form off dixlexia. i maneged to swits most averything backwarts.it would explain many things. david is awesome,the patients he has but also he checked me to see if, i understood what he's asking.now i see the beauty off the tutorial.
tomorrow another awesome jd day.
thank you bolt.
