User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Meet The Smart Saltwater Aquarium Powered By Ez Robot
Ez Robot community I wanted to introduce my latest application of this system. Some members hear already know I keep two salt water aquariums one coral which unfortunately died off and my predator tank. Sea life needs delicate balance maintained in their little ecosystem. Things like light spectrum , temperature, ph balance , current of water , nitrate and ammonia levels and calcium levels. These things take a practiced hand to maintain. I am building a new system and using ez b to monitor salinity, nitrates and ammonia, temp , water current flow and the ph. The ADC ports are useful for these and EZ board can control the current and switching to a backup power supply ( a apc for computers inside the cabinet to keep ezb and pumps powered). Also the ezb can turn on and off night , morning , day , and evening lighting settings. With a custom injection device im designing ezb can provide nutrients , calcium and even medicine if levels are out of wack. I started the build today and I am very excited!
#145
72 hours after I added the uv sterilization it looks like the algae spore outbreak never happened. Tommorow I repair the refugium where the massive buildup of spores broke some of the walls loose.
#146
Going into the 4th day by about 8 hours...
Wow that's a rapid and dramatic improvement!
#150
looks very clear,that first one you had up i never seen atank like that,may be the wrong fish or setup that cause that You need a right balance of fish,coral and plants and not too much of each
#151
I took water samples and pictures of fish and setup to three different salt water dealers and they all said the setup was ideal and I would just need to give it a few days to do its work..... so here we are now:)
#152
That is incredible Josh. Good work. Now I see where you got the bright idea for Dusty (lol)
