Hi all,
EDIT: the below post has been changed to reflect changes to correct wrong information and show the successes I had with the proper wiring information I received from the fabulous EZ Robot Support team:
I spent some time over the past couple days seeing what I could do with the sound that can be streamed from my computer and played through the EZB V4. First I gotta say I'm no sound engineer or even a weekend garage installer. Just a simple guy trying to stitch this all together and learning along the way. Sound systems are one of my weak points (among a lot of other stuff )
Anyway, I first have to say that the little speaker on the V4 EZB does an amazing job for it's size and what is asked from it. It sounds pretty good but if I relied on it for the voice if my 400 pound B9 robot he'd sound like the Mayor of munchkin town.
My B9 has 4 sound systems. One is stand alone and plays background mechanical sounds through it's own amp and speaker. Two more (EZB V4's streaming sound and a Bluetooth receiver) play through the same amp and speaker and are sorted out by an auto AB switch. They play through the CF Sound system's auto switching input jack and it that can also play it's own sound files. The robot's chest neon is triggered by one of the CF3's speaker outputs.
So, what do I do if I want to Stream my sound files through my B9's main sound system with EZB? The V4 EZB has two little holes on the bottom board marked "Speaker". There you can solder in a couple wires and add another somewhat larger speaker. I first tried to wire in my sound system to these two holes and quickly found I had to also add a ground wire to one of several spots on EZB's grounding grid. I chose the square solder pad marked GND that's right next to the power plug on the bottom board.
However, when I wired my speaker and amp to these speaker through holes I quickly found that the sound was flat and tinny. EZ Robot support quickly explained that that is because these two breakout holes are "after" the onboard amp. So, If you are using a setup where you wish to use the amplified audio from the EZ-B, then the two solder points marked SPKR on the EZ-B are to be used. To get high quality sound output to my own amp I need to use the provided solder pad that is located before the onboard amp. Jeremie from EZ Robot told me: "We made a small solder point called a via available at the input stage of the amplifier and true high quality audio to be used for inputting into an external amplifier. The via is located to the top right of the amplifier chip when looking at the main board from the top, you should see it no problem from the bottom too as it's the only other through-hole pad that isn't soldered in that area of the board.The connection will be as follows:Via to right (or left) audio channel. GND to GND audio connection"
So I rewired like Jeremie suggested and was amazed at the difference. The sound was crisp, clear and deep. Here's a few pics of the process and a video where I hope you can hear how well this sounds.
I damaged my MP3 Trigger the other day beyond repair so I de-soldered the 3.5mm Mini Plug and built a breakout board to easily plug into. Here I have everything laid out and ready for assembly:
If you just want to add a small un amplified external speaker this is where you solder the wires, Important: adding the black shrink tubing helps to keep the solder joints from digging through the insulation of the wires and a causing short. In this shot you can also see I've removed the little power pin that sticks out the bottom of the board and installed my own Piggy Tail power connector using wire and a Molex connector :
Here's a shot of the solder job under the project board that I bought from Radio Shack and cut to size:
Here are a few pics of the locations I soldered the the wires to "before" the onboard amp:
Here it is all put together and mounted in the neck of B9:
Here's a video I made showing it in action and attached to my sound system through the 3.5mm Mini Plug that attached to the amp. I try to compare the fidelity of the already installed CF3 sound system and the streaming V4 EZB. Both play through the same amp and speaker.
I conclusion; EZB V4 does an amazing job making it easy for you to stream sound right from your computer to the board itself. Adding an amp and large speaker can be easily done and the sound is very nice. I'm thrilled how clear and deep it sounds. However I think your true results will depend on the quality of your sound files. I both .wav and .mp3 files and and heard a range of fidelity. Again, the better the sampling the better your file will sound. Also you can adjust sound quality with the controls on the amp and a good speaker will make all the difference in the world.
Before I got the V4 and tried to stream my sound files over the WiFI connection from my laptop to the EZB v4 I was using a SparkFun MP3 Trigger and the V3 EZB. The current setup is much easier to use and the sound when sep up like this is comparable. Again in the end it will all depend on your sound file's quality and how nice of a amp and speakers you use.
I hope this helps and you enjoyed.
Dave Schulpius
Hey @Dave,
Thanks for the detailed post and video!
Before you go back to the MP3 trigger I wanted to suggest that you try something else. You see the speaker ports you tapped off of are the output stage of the onboard audio amplifier and are tuned for a 8ohm 0.5W speaker which doesn't allow for much bass to get through. We thought of this and made a small solder point called a via available at the input stage of the amplifier and true high quality audio to be used for inputting into an external amplifier. The via is located to the top right of the amplifier chip when looking at the main board from the top, you should see it no problem from the bottom too as it's the only other through-hole pad that isn't soldered in that area of the board.
Via to right (or left) audio channel GND to GND audio connection
You should just be able to change the 2 solder points that you connected to the SPKR pads to the ones above and you should get some great sounding audio.
Hope that helps!
Wow, great news! Thanks!
As I said I'm no expert so I need to ask a couple questions. I marked the hole I think your talking about. Could you confirm this is the place to solder to:
Also, There is only one Via through hole you point to. Where do I attach to Ground? The holes I soldered to that are marked Speaker there are two holes. Are one of these considered Ground? If so which one?
Yep, that is via! Neither of the two SPKR connections is Gnd so you'll have to take that connection from either the four unlabelled vias beside the micro deans connector, the pad labelled Gnd on the other side or just tag onto an already populated pin labelled Gnd. The later is probably the easiest.
Also, technically if you got a larger speaker with the same power rating wouldn't that be louder too?
Thanks for the video and explaining v4 sound.
J
@Technopro yes, you are correct that a larger speaker cone usually produces higher volume audio, just be sure to impedance match (you'll need an 8 ohm speaker rated for 0.5W or higher).
@dave,
Hopefully you have time to update the pictures on the suggested connections from Jeremie! Always a great help when searching in 6 months for the post and info!
@Jeremie- As I understand it, Dave has 3 soldered points, 2 at SPKR and 1 at a GND. When/if he moves his set up will he only have 2 connections then? One at VIA and I imagine he could keep his GND.
@Dave- Thanks for the info and vids showing off your V4. I have a Roli kit ordered so I won't have mine for a few months still, I'm guessing. Amazing work. I can't wait to hear the difference once/if you re-wire it using the VIA.
