Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Adventures Of Botchy
I thought I would start a new page. I would like to completely delete the old stuff. I will have pictures soon. They are already taken. I have had my struggles, so i named her Botchy instead of Sunshine.
Here are some pix:
Thanks for your support!
:D
That is what I have so far.
#81
@MovieMaker... We all do this for stress relief, an escape from life... This is fun and an extension of our childhood... Find a way to get back to the fun....
#82
Thank you, my friend. You are a wise man.:)
#83
Ok, I have the Head and Eyes rebuilt and I have rebuilt the arms so many times that i have to tape or glue them back together all of the screws are stripped and the connects broken. I rebuilt them each two more times without success. Then I decided before I totally scrapped them, to just skip the lazy susan parts and run them straight. They seem to work. So, instead of having a Lincoln, I will drive a Pinto. Time will tell. i have put on the tray for the mimo monitor and have also installed a holder for the W3 on the back. I have made the neck straight instead of leaning. I have re-done the base. I will have to wire everthing up once the glue and expoy and silcone dry.
Wish me luck.;)
#84
Pinto! Didn't they blow up when they got hit from behind (or was that the Pacer)?
Nice progress! I'm glad things are going better for you and your little gal.
#86
My Cady is turning into a Pinto as well. I'm hoping to end up with at least a Pontiac when I'm done. Keep it up. I think you're closer than than you think.:)
#87
Thanks for the encouraging word. Things are looking up. I have worked on the base, sensors, and I am now wiring the arms. It should be all back together in another week or so. Will it work? we will see. don't know. But, I think it will. I am planning to upgrade both arms to the Lexi arms. And, Tony(Toymaker) has sent me or will be sending me a powerful servo. so, at this point, I am very optomistic.
#88
Well, it is official. Botchy is paraplegic. I have removed the arms awaiting new part to come in. I have found that one of the ezb's has been blown and I have to repair it.
Thanks for your support!;)
