Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
#81
Thanks very much. This is really driving me nuts but I think I'm getting it now. I don't see arrows when I go to the bottom left corner or something when I go to the left side. Maybe this function is turned off. I check it again. Where do you hit on the screen to get things to pop out? I guess it will take a little time. Thanks Ron
#82
Sorry, I don't know what arrows you mean. What you will see is a Windows icon which brings up your system menu.
What "things" do you mean by "pop out"? if you mean the charm bar, move your mouse pointer to the very edge of the right hand side of the screen. Then quickly swipe your finger from right to left on your mouse/track pad to bring the charm bar out. It takes a little practice, but you'll get the hang of it.
A piece of advice, play about with the laptop first before jumping in to ARC, and if your stuck on anything, there's lots of "how to's" on the internet regarding using Windows 8 which you should find helpful.
he means this one,it chould pop up when you use mousscroll
#84
Ah, gotcha. The apps menu arrow. If the laptop supports it, you can use two fingers and scroll up using the mouse pad from the bottom of the screen to show the apps menu.
darticus
here some more pics
Thats it. The task bar always shows. I now have ARC on the task bar. The arrows don't show when you go to the edge or corners. The apps menu arrow shows fine but the ones that should pop out when you go to the edge don't seem to show. I'm not using a mouse only laptop pad. I am getting there now. Thanks Ron
darticus
by a mini mous,much easier.
#88
I will give it a try. Thanks Ron
