Anyone managed to hook one up to the EZB yet ?............just curious.
nanomole40
— Edited
Speech Script
— Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs.
Here is some test results from my cameras:
My Omron Original HVC-P camera range detection for hand is better at about 4 feet. Body it does not detect well or often. 4 foot is also the max range for reliable face detection and it gets better closer I get to the camera with 3ft or less being best results.
My demo Omron HVC-P2 camera could start to detect bodies, hands and faces at around 9.5feet. Body detect was best at 4 feet away or further. Hand detection was best at 3 feet away or further. Face detection was best from 6 feet and closer depending on lighting.
In all of my testing overhead lighting can really negatively impact the sensitivity because of the shadows it can create.
I reloaded everything and still get the B5T-007001 folder which is where data is stored. I will go in and remove all old stuff and the 1.2 software and what ever else.
Hi Justin,
if you want i can you give the 123Design files.
There you can move the single pieces, if you want to change something in my design.
So now i make a BIG Test.
hear you later...alligator ;-)
Ended up with the same issues.
Should I try pulling out any folders or files and Move the data in a specific folder?
My initial need is the Facial Recognition. I will gather data on the info you, Boris and Mickey are working on this afternoon.
Ron
Boris, Thanks for the enclosure ! It meets my needs perfectly !
Ron
@Ron, thank you for checking everything. It sounds like you need sit tight for now until I release a new revision with a configurable path for the album path.
I should be able to fix it by the end of next week at the latest if not sooner.
Right now the album path is hard coded in the plugin, which would be fine if the evaluation software treated the album data all the same which I assumed it would because evaluation software in conjunction with the camera is what creates the albums with the trained user faces.
What appears to be happening is based on the particular firmware of the camera the ROM in the camera which is sending back an album path folder which means different cameras will create different albums.
And @Boris, that would be great, I would like to see the 123Design files. Can you send them to my gmail address? You can find my gmail address in my profile.
HI Justin!
So i had a middle check up!
Everything fine with the plugins!
Fixed: Hand and Face X Cord. now works !
Omron.exe works fine (if the correct COM is selected and the correct Album is copied ;-))
If find out - if you work with two omron cams - My lovly PC gives everytime a different COM Port to the CAM. If i want to have it with out problems or select the right COM Port, i must plug and start all thing like a solder in the army. Exactly in the same order! But this is my problem because i want to use two CAMs
To the Album Path:
It would be nice if the plugin only needs the "B5t...." Folder for the Album and not also the "HVC-P" Folder.
So we can use the "Omron.exe" to start can dcheck the album and the plugin read from the same folder.
Now i must copy it twice.
But i read you are on the way to change it in the new update.
Other Idea:
What do you thing about a LOG file?
Like our Project "Read and write Data"
So i mean an automatic generated txt file where are this infos/data waht i want.
Like to have a option in the plugin ( like a checkmark)
LOG File yes/no Time repeat (how many seconds/minute) which Values
Then you know, i can write a script who reads the data from the file and i can do or the robot can do what we want with the data ;-)
Because the hole idea of the Omron Camera: IS TO HAVE DATA!
It's a men or woman? It's me? It's a human?
SO in the end, i don't need the Camera, i need the data and the time ;-)
But this is only a Brainstorm
Boris
PS:
I will check now the 123d files. Also to Andy... if you want to change something in the design.....
Sounds Great ! Thanks
