Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
#177
Hi Justin, Hello Boris, Hello Mickey
I got everything running. I, like Boris, thought I needed to run the .exe.file to run the prog. With the clarification it is working. It is nice to be able to jump over to check the camera and data.
I am still having no luck with the facial recognition. The original load put the face data in the HVC-P2 folder. I then reloaded everything and saved the data to the HVC-P and tried HVC-P/O folder. Still no name shown. If I go to the camera, the data is shown. I do show the variable in the ARC for accuracy of the facial data, but no name.
I have a script running a loop every 500ms which gives a reasonable refresh.
I can pull out everything again and try to load again.
Ron
P.S Thanks for working on this. It is appreciated.
#178
Justin,
I found the data in
/EvaluationSoftware_rev.2.4.1/B5T-007001/0/RegisData/000 or /001
(I had made two different faces 10 images in one folder, 5 images in the other.) I did not select any special location to save the data, or change the name of the folder during saving.
Ron
#179
Justin,
Looking at the files Mickey has I noticed I have two additions, in the software.
B5T-007001 HVCAlbum.hac
The data for facial recog. is in the B5T-007001 folder as I stated in the previous post.
Ron
#180
Thanks everyone for testing, I appreciate it!
@Mickey666Maus, you are correct, everything is required just like @DavidCochran's original plugin. I'll add more details there to clarify that.
Mikey, which camera do you have the HVC-P (original) or HVC-P2? And what is the model number?
Boris, what camera(s) do you have the HVC-P (original) or HVC-P2 And what is the model number?
Because both of yours are working, which is great! I just want to make sure I know why yours are working.
@Ron, your directory path is really out there in the weeds! You have a HVC-P2 correct? What is your model number?
It is certainly weird behavior, because from a programming standpoint I would assume the album path would be hard coded in the .exe of the Eval software but based on the documentation from Omron it appears the Album folder name comes from the ROM on the camera, which make sense from the results we are seeing now with different folder names.
To fix this I think I need to add a config setting to set the path of the album so it is not hard coded and everyone will have the ability to set their own path.
#181
It is a B5T 007001-010.
I will dump all the old plugin stuff and try the new. I will let you know what is going on once I'm done.
#182
Hi Justin,
sorry i had no time to check again, but later (after a meal) i do more testing.
Fot your queastion:
I have the old HVP-P and the new ones
HVC-P2 (010) and HVC-P2 (020) - so all what they produce!
Hello Andy!
Hello Mickey!
Boris
#184
You are AWESOME Boris! I had started to design boxes for the P2, this will save me a lot of hassle!
