does anyone has done the offset from jd? and second howmany degrees is jd neck ?
— Edited
9 Participants
Irobot Roomba Legacy
— Legacy iRobot Discovery and 4xxx control via EZB software-serial (D0), supports Arduino/EZ-Robot, adjustable baud rate; not for hardware UART/USB
@Alan I believe the right term is "steely eyed missile man" ... @d.cochran there is a collective sigh of relief... way to go dude...
Now if we can only get @Nomad to finish his tutorials then a true miracle can take place....
d.cohran
its amazing to see how you know all this.and your voice is very plezant. i injoy it avery second.extremly helpfull.you are my hero to.
thank you thank you thank you
rr
david show me what the tutorials is all about.especially the calibration. the miracle will soon taken place.
:D
Ok @Nomad.... can't wait for your video of JD dancing to YMCA....
rr
am doing the callibration now,and found the problem. his left ankle was only 1 degree insteadt off the 90 degree.
That wasn't the problem... keep calibrating, keep going through the lessons, get JD set up correctly, assembled correctly and connected to correctly. The rest will be simple.
Patrick, Rich is right. Make sure all of them, especially the shoulders are physically at 90 the way I showed you.
once that is done, continue down the tutorials. We can get him calibrated tomorrow at 3:00 pm or 4:00 pm your time if you would like.
hi d.cohran
yes i would like that.sofar problem whit choulder and D81D5
aldo he did say i am jd
@Nomad.. you still haven't done all the tutorials... Do this one Shoulder Calibration to calibrate his shoulders properly
