I was wondering that it was possible to connect an neopixel ring(16) directly to the ez b4? If so, where do i connect the com port to ? tnx
DigiEddy
— Edited
Camera Variable Overlay
— Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options.
so if i understand you david pin 18 and 19 are bolt connected to the black pin on ezbv
not at all.
the black from the ezb goes to the ground pin on the arduino
The white pin goes to the receive on the arduino. It all depends on which port you you use, but if you want to use the sketch that Luis provided, the documentation is available in the tutorial.
i didn find the sketch
https://synthiam.com/Tutorials/UserTutorials/150/1
This is a sketch. This is what arduino programs are called "sketch".
Also, my bad. It was Bob that put this tutorial together, not Luis.
When I get time, I will provide a step by step video on how to make a neopixel ring work with the EZ-B through an Arduino. I just don't have time until after this weekend at the earliest.
thats great thanks david
@Nomad6R, I just updated the tutorial for connecting the Neo Pixel ring to clarify that the "Signal Pins" on the EZB are connected to the RX and TX on the Arduino. Did you get yours working?
hi bhouston
i dont have one,my friend has one and was able to get it working. wiht your help.am going to see your tutorial now
thanks
