Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
Mini Itx Cheap! Dell Atom 330 29.99
Asendtech has several of these tiny 6 in x 6 in mini pc / CPU combo , just 29.99 , very very good option for a autonomous robot (a person doesn't need to be at a computer or laptop wirelessly controlling it ). These draw about 12 watts. I just bought one , get them while they are hot! - Josh
#57
just do a search on ebay for dell fx160 ,then ask if it has atom 330,i would set it for the lowest with shipping first,to get the lowest price for one
#58
@BC referencing page 5 of Dell Optiplex 160 Technical Guide Could your tell us if the 5 Audio Connector (AUDIOF1) and 7 Front Panel Connector (FRONTPANEL) on the motherboard itself are labeled with pinouts?
#60
Only go for a atom 330 or higher , that's dual core 1.6ghz. I've.had a machine.just.for surfing that was so single core 1.6ghz and it was not a quick as I would like. I found a 40 percent improvement spending a few extra dollars for dual core
#61
I have a wimpy toshiba netbook and if i have both voice recognition on and face detection, it does not want to sync up with the bluetooth. Need to shut most of it down before connecting to bluetooth.
#62
Yea that's possibly a good example of "underpowered". My system uses a AMD 32 nanometer chip , uses 20 watts , dual core 2.2 GHz 2mb cache , 4 gig ram. It's a newer idea of taking good chipsets and shrinking them. The comparable desktop CPU is 60 watts. Anyways a dual core is the way to go , these single cores can't do everything you throw at them , 64 bit systems do a lot better job (utilizing cores better) without 64 bit is the dual cores run in a sort of hyperthreading mode but not both cores full time , they take turns each clock cycle processing data.
#63
problem since i work with computers for a very long time,its not really the speed, its the memory and resources i have a notebook running 1.6 mhz 4gig ram,it runs everything great,but i tuned it up you need a program called XPLITE,it removes programs and resources not needed.there so many using the memory and then you try to open a program it wont start fast or be slow you should see how many many programs on the robot computer not needed
speed does fix the problem,BUT as more speed or power so does the heat and battery usage goes up
in XP PRO and other operating systems there is a program that tell you how much memory is used called WINDOWS TASK MANAGER (ctr-alt-del) memory should be half of the installed memory with all programs running ,and there is a CPU usage meter telkling you how much the CPU is using ,should look at near 35% ,mine i have it at 20% or less another slowing down computers alot,seen to much i have to fix at work ,till they got another IT computer guy,is they need disc cleanup and DEFRAG
