well i finally got the guts to try to solder on the ezbv4 i solder a mouth led straight on the ezb. use a bride led
— Edited
11 Participants
Pandorabots
— Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots
@nomad18.08 you have come up with a simple and excellent solution! Did you get that LED locally or off ebay? I can't find one like that anywhere
hi tony
i by them from conrad.be or conrad.nl
make sure you test a led whit the resistor on if its bright enough.
Thanks @nomad18.08 I'll have a look!
Sorry to bother you again @nomad18.08 I have searched through the massive conrad store but cannot find the LED you have shown in your picture on the previous page There are plenty of LEDs without the black socket (as per attached pic) Is the socket a separate item? Do you remember the name of it?
tony i will look it up see if i can find it back.
tony here some links
led fitting
led
maybe someone can chime in for howmany mcd tony will need.
tony you find alot on ebay.us
Many thanks for your help @nomad18.08 ! Yes, they are very cheap on ebay!
i checked my oreders from that year.i see two leds. one 200 mcd and one 4000mcd. i cant remember whits one i used. here a link all kinds off resistors.
resistors
