well i finally got the guts to try to solder on the ezbv4 i solder a mouth led straight on the ezb. use a bride led
— Edited
11 Participants
Wowwee MIP Movement Panel
— UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration.
thanks steve S
@nomad... Just a reminder the white digital pin can only supply about 20mA... so just be careful what to attach to that pin as anything more than 20mA can damage the port...
rr
for leds i use only black/red
@nomad... maybe, but without the digital pin you can control them... PWM is on the digital pin (white) not the red pin. If you are going to use @bborastero's script you will need to use the digital pin not the power pin...
@thetechguru
agreed I've noticed the same thing. still I like the hard wire choice too.rr
ah.thanks for telling. so i use black/white and sound servo to get same or better result?
The results will be about the same. Only advantage of the script and sound servo are that you can turn it off if you want to make other sounds without the mouth blinking.
I think your solution may actually work better.
oh really ?
thanks for telling alan
