hi tony
its actully round.
hi @nomad18.08 so you just drilled a hole? Do you have a small resistor wired into the red line?
Thanks @nomad18.08 Would it be a 1K ohm resistor?
hi tony.
i make a pic cause i dont have knowledge about these things.
Thanks @nomad18.08 ! Now I see how you got the neat black trim around the mouth:)
it clicks together and the led stays in place. the little ring has two sides.one side start the treath in the begin off the ring for , thinner plates.the other side start a little further for thiker plates. i melt the hole whit a little iron screwdriver and then whit a little round vijl, make it bigger.
