Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
I think this might be looking for. Here are slight changes to what you have, and you will want to add you Cheat Sheet commands in as well. Give it a try and let us know if this what you want...
# This will clear the selected servo
# speeds for initialisation.
ServoSpeed(d2, 0)
ServoSpeed(d3, 0)
ServoSpeed(d7, 0)
ServoSpeed(d8, 0)
ServoSpeed(d4, 0)
ServoSpeed(d5, 0)
# Move the servos into initialisation
# positions where you want the servos
# to start from.
Servo(d2, 2)
Servo(d3, 180)
Servo(d7, 18)
Servo(d8, 77)
Servo(d4, 163)
Servo(d5, 105)
# This will set the servo speed for
# these servos which will be used
# from now on.
ServoSpeed(d2, 5)
ServoSpeed(d3, 5)
ServoSpeed(d7, 5)
ServoSpeed(d8, 5)
ServoSpeed(d4, 5)
ServoSpeed(d5, 5)
# Then add the rest of your control
# command scripts here...
Also one peace of advice. When you want to share scripts in a post, it's better if you use the UBB code. That way it's easier to look at and easier for someone helping you to copy the code and make changes.
Write or copy your script where it says "text" inbetween the [ code ] and [ /code ] UBB codes .
Hope that helps.;)
it works perfect.
code text code dont understand how that works?
No problem. Glad it's working the way you want it to.
In regards to posting a script, if you don't mind, I will try to teach you how..
1) First, you need to use this [ symbol
2) Then write the word Code
3) Then use this ] symbol
4) Write your script, for example, Servo(D5,90)
5) At the end of the script use this [ symbol
6)Then use this / symbol
7)Then write the word Code again
8) Then finally use this ] symbol
It should look like the following picture...
Or you can write it like this...
And you will end up with this when you post your response...
Servo(D5,90)
I hope that helps:). It just makes it easier to make changes or to test someone's script without having to re-write the whole thing. If you want, post a reply back and give it a try.
servo(D2,0)
servo(D3,0)
(servo(D7,0)
servo(D4,0)
servo(D8,0)
the code you teach me
how do i get this on one black page?
Yeah, you got it.
A you need to do is put the first [ code ] at the start of the first line of the script, and the [/ code ] at the very end of the last line the script...
