Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
@Moviemaker Dude I don't have any medical condition going on, but I have terrible memory. I make up for it by making notes. I find that writing something over and over again is how I memorize stuff...I remember and understand better when I see myself writing the words in my head. It may work for you. My 2 cents. :)
thanks doombot,mho.
scan turns up blank.
It doesn't boot up properly. I have pulled it out of the robot. When you hook up power, it just flashes the green light. that is it.
I think the firmware has gotten messed up. It has no sound.
@Moviemaker About the sound, do make sure your speaker is properly seated in there...it has happened to me, when I opened the case and put it back together the speaker just stopped working. Just make sure the springs on the speaker are touching the leads on the board.
@Moviemaker, you could trying pushing the reset button, find a paper clip or a small pin, push and hold it for about 8 seconds. Release the button and see if itales a chime, if it does it should then flash blue.
If this work,et us know.
I will do this., , , , ,
No effect . Same.
#15
When you say same is the light blink green or blue
#16
Green Light is slowly blinking. No sound, not internet. just blinking green light.
