Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
Amazon Echo
I have purchased an Amazon Echo and am very impressed with its abilities. I would like to know if there is any way to merge my Echo with EZB so I can get the benefit of both systems through my Echo. This sounds confusing but I want the benefit of information and voice interaction of my Echo and the Robot control aspects of EZB by using my Echo's great voice recognition. I love the Echo speaker system and microphone and its ability to answer almost any question. I also want to use the Echo for voice commands to the EZB and I want to use the Echo voice for both.
I realize I may have to use Windows Cortana since the voice comes through Windows but I like Echo Better and it has the ability to connect and control items through IFTTT.
#41
HAH
That's great! Just played with it and it seems to work very well.
#42
I did to and it worked well. Should be no time until an app is made for Ezb.
#43
Just ordered the Dot to connect ALAN. I guess there are several hoops to jump through to get it ordered. They only want to sell to early adopters so you have to use the Echo to pre-order although there is a work around using the Amazon apps but will prolly close that hack soon. The Dot was about $90. Won't get it until May. Very limited stock. But it connects via Bluetooth or 3.5 Jack.
Portugal
#44
Here is an app in python for RPi2 to use Echo. You must always have a trigger (input) when talking, that is the only downside.
#45
If anyone is interested in trying Amazon Echo (Alexa) with EZB before diving into developing Skills or the API, I'd like to suggest you try your concepts using IFTTT. Its not as elegant, but works as a proof of concept.
IFTTT already supports a few Alexa commands. I use the Amazon Alexa Channel to create a verbal trigger
Then I use the Maker Channel as described in another thread to send the command to EZB.
Execute Scripts Or Commands With Http Get Commands
