Ultrasonic Collision Detection icon Ultrasonic Collision Detection — Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling. Try it →
Alternative Mp3 Trigger Sound Modules
I started testing some alternative MP3 Sound Modules, my goal to get similar functions but at 50% less than the cost of MP3 Trigger ($50 + s/h). This could help people with low budget that want to get into robotics or just wanted to build a low cost robot. I choose these two modules in theory from reading their data sheet should work with EZ-B thru very simple sendserial command already built into ARC:
This MP3 module im testing and is working very well with EZ-B, it supports 40 MP3 files, 6 outputs:
40MP3 Module
Specification
This MP3 module supports 199 MP3 files and 8 outputs but I can't get it to work because it required baud rate of 4800 which ARC doesn't support but i would like to have it working because it supports 199 MP3 files and have better features than the above module:
199MP3 Module
Specification
However both modules needs an audio amplifier but for the price you can't beat for small to large robot projects that don't need a lot of sound files.
I have already got it working well with my Wall-E project, there is just one problem because the volume reset once power is disconnected so i found a way around that by using a init script at connection to change to max volume and a start up sound. All costs less than half price of MP3 Trigger:).
Here is a rough wired pic using Wall-E own speaker, MP3 module, and a dual 3W amplifier. I will post more details soon but still i would like to be able to use the 199 mp3 module, nice thing is both module output stereo sound and you are not limited to small speakers, just use bigger amp for bigger speakers and blue color matching EZ-B board:)
More details on wiring and custom scripting coming soon...might make a demo video if i have some free time.
#57
by adding a pot you can limit the volume and at the same time keep the speaker from going bad
#58
Okay Louis T, I got my amp, mp3 trigger, and sound bites for the robot. Thank you for all your work on this cheap alternative. I will be working on it this weekend and hope to have a video of B9 speaking - Yay! On a side note, I have a little over 100 clean B9 voice clips in mp3 format if anyone wants a copy . Just let me know and we can figure something out.
#59
So if we want more than 40 phrases we need a second ezb ? Or can ezb control more than one of these boards?
#60
@ bret.tallent...That is cool, im glad to see others using this method:)
@ jstarne1...I believe you can hook up as many boards as you need, because it doesn't use the native ARC MP3 scripts, so just use the sendserial command to different digital ports so it can tell which board to play which track.
#61
Okay, got my memory card loaded with my 40 mp3 files last night. Tonight I will wire everything up as you have outlined previously. And if time permits, I will play a track.
#62
Awesome brett! Thats great. I need to get a couple of these mp3 boards. The initial link shows them sold out. Where can I buy them? Thanks guys
#64
Well I dont know which ones are compatible or not. What should I look for?
