Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
#217
you can switch back to the wireless connection to your home wireless and then go download it, then switch back to ezb network.
nothing works.on android.can we try on pc? i need to make a new one and delete the old ones apps
#220
Nomad, here is the issue you have.
  1. your android can connect (it isnt running any virus software or anything so it is easy to connect to the EZ-B)
  2. you can see that the connection is working by being able to access the V4's website.
  3. you cant get the EZ-B onto your network because of either wrong SSID, Password or incompatibility with the Wifi access point.
  4. your PC has issues connecting to the EZ-B V4 but can connect to your wifi.
the best solution is to get the ez-b onto your wifi at your house because your pc can hit that network also and you would be able to be on the internet and connect to the ez-B.
Charge your battery and we will attempt again, but I think the issue is probably either the ssid or password. If it is not that, you should go get another wifi access point IMHO.
Please verify your SSID and your password first by using this information on your phone or on your android to try to connect it to the network. if it works there, then you know you have it correct and the issue is an incompatibility with your access point. I can recommend some to you that have shown to work. they are about $50.00 US.
Let me know after you have verified these pieces of data.
i know my password&ssid perfect
ok i will charge the batt now.see you later thank you
#222
I have got to go help my daughter with homework she has gathered from being out of school the last week. This will probably take some time, so I don't know how much time I will be able to be on today. I will check in periodically.
#223
Nomad, we have a videos with the entire connection procedure.
  1. Can you tell me what's missing from the videos that will help you?
  2. I don't see in this thread if you've been able to connect and control JD from AP mode (default mode). Is there a reason why you're skipping to a more difficult connection method?
  3. When you load a project on android from cloud, it is cached in your local projects and you no longer need an internet connection.
  4. Why are you not using the default JD project that ships with ARC and ezcloud?
d.cohran that ok thanks for trying
dj i just want to use jd whit pc and there is a problem he dont connect the ez-b
jd makes some spastic moves when i turn him on.so i would correct that first , for the safety off the robot.but cant connect.also when norton is off.
on android it works,i can see camera and mic also works.
no acses to the server ez .
your video is good,my problem starts before your video.
am not a programmer so i cant solve it.
