just got mail from ez ,my order is chipped.
— Edited
Feetech Serial Bus Servo
— Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration.
seeya later thanks
Hey nomad my balancer charger(blue block) gets pretty hot too I think that it's normal. When you plug the AC input the red light will always lit up to indicate there is power coming from the wall plug, once you plug it with JD there will be a green light to let you know your robot is being charged. After charging is completed the green light will go off this means your robot it's completely charged. The red light will still be on of course and the balancer charger will cool down
hi bautista yes batt and charger are fine. are you able to connect to pc and android?
I am able to connect with my laptop, it was very easy, I even started making some dance moves on JD, butI haven't tried connecting to an android though.
what did you put in here?
I did not put anything I didn't have to go there to connect JD
From what I saw on the video I believe you get to chose your password, if you leave it open I don't think you have to put anything where it says security key
do you have win7? i cant get it connect
