Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Vr Options?
Does anyone know if the SDK of the Oculus Rift package would work with EZB if there was a plug in developed for it? It doesn't really need to be something as big and bulky as that. Very unfortunate that Vuzix is no longer offering support with EZB. That would work great.
Like the Vuzix, I'd like to pull from the IMU data to move servos and transfer the camera feed from the EZ camera to the goggles over two complete separate computers in different places.
Any ideas or suggestions on how to POC this, would be grateful.
Hmm wonder how I missed this? Has not been updated in some time. I’ll have a look and see if this will work for me.
If this was for the DK1, what version did you have and test with?
I don't like that you have to tilt your head for rotational values. Wonder if there is a better solution.
There is a better solution if you use the tracking sensors. They’re external sensors that you setup around the environment. Google on the products you’re looking at will tell more detail. The only headset that I’m aware of which doesn’t use external sensors is the windows mixed reality
You’d have to look into their sdk to create a plugin for ARC.
I've been looking at these FatShark headsets for flying drones. They have a built in pan and tilt head tracking for 2 servos and camera feed. Wonder if these could be modified to work like the other headset plug ins? Not so cheap tho.
Ha we posted at same time! Ok sounds good I will look them up.
