hi
is there a window for talk servo with led?insteadt of inmoove mouth opens, while talking,but with a led then.
Drone Collision
— Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance
hi
Bobsheaux
the sync off the LED wil not work 100% correct.you will need to try diff kinds off LED. you wil need clear LED with higher MCD .some between 500 and 1000 mcd also you can tinker a little with these settings .
there is another way to get beter sync for the LED ,that is solder the wire on the pads from the speaker. any sound that comes out the speaker,the LED will flach same ritme.here a video.this way you cant cotrole the LED itself.
Hi @Bobsheaux,
There are a couple methods in hardware that you can do. As Nomad mentioned you could use a Super Bright LED that has a high millicandela (mcd) value.
Another way to make it bright is to use a transistor and adjust the resistor so that more current gets to the LED. An LED hooked up to an EZ-B I/O port is limited to 10mA by the on-board resistor but you can still use an I/O port to control a transistor to get access to more current.
Rich wrote a great tutorial here about using a transistor to control a bulb. A TIP120 is a bit overkill for your application but you can use the same concept with a common 2N3904.
One thing to note is that with PWM you'll always want to stay near the higher percentages for your on time as that will keep the LED bright.
Come to think of it, I like Nomad's idea of using the speaker voltages to activate the LED, it would need to be attached to the amplified side of the amplifier (extra speaker pins), combine that with a transistor circuit and I think that could work well.
hi Bobsheaux,
I see you have sound servo mic - wrong
under servo you need sound servo (PC)
EzAng
@Nomad So in THIS tutorial... https://synthiam.com/Community/Questions/Breaking-Out-The-Sound-From-The-V4-Ezb-8463 ...Jeremie says that positive or negative doesn't matter when hooking up an external speaker to the EZB (post #32). How exactly is the LED in your last video hooked up to your speaker?
hi bobsheaux
iff you take for excample a white wire and solder on the SPKR .
then connect the ezbv4 to your arc.
then touch with the wire the pins off the speaker.only one way will work.
as jeremie stated color positif or min does matter.
here you see color red on the left side.but it works also with the red on the left.
its the other side of the wire thats going on the speaker that you need to test,
Okay, but how did you attach your LED to your speaker? You said you soldered it to the pads of the speaker? The soldering I understand, but what/where are the pads of the speaker? Apparently it doesn't matter in which direction you solder the wires of a speaker to the EZB, but I wouldn't think that's the case with LEDs, right? The proper position of positive vs. that of negative DOES matter, doesn't it?
these are the pads off a speaker.
it doesn matter on the ezbv4 what + or - is.but on the speaker or LED you have to test wish wire goes where.
you can use colored wire if that easier to remember witsh color goes where.
1 solder a wire on the ezbv4 ( long enough ) see pic ptp
2 strip the wire on the other side .
3 connect your ezbv to arc
4 play sound file or sayezb
:loop
sleep(2000)
sayezb(" testing my speaker ")
sleep(2000)
goto(loop)
5 tough with the wire the pads from the speaker ,if you dont hear sound switsh sides .mark one wire so you know wish pad it goes.
6 sound file is still playing ,now connect the LED and see if it lids up ,if not swish sides and mark one off the wire.
7 connect the wires that youve marked together ,and connect the two together that doesn is marked.
8 solder the wires on the pads or you can use one off these see pic.
But where am I connecting the LED? The speaker has positive and negative terminals, you hook those up to the EZB, but where on the pads do you put the LED? I need to reiterate the point that I'm not trying to be confused or argumentative here, but it sounds like you're telling me to just put the LED anywhere and that will work.
