Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
#73
No. Bobsheaux didn't get it...
I'm using the Sound servo (PC) controller, I used the new script that you wrote, I've got one PWM window running... and it's STILL not working.
Line 1: Unexpected token ILLEGAL
if you have two leds ,you chould have two pwm .
line 1 is nothing.
are you using ez script or somthin els ?
#75   — Edited
sorry Nomad, I did not see you
try the talk servo
use the controls I have
make the min 1 and the max 180
EzAng
#76
Let's see what happens with this set-up...
ok, you can do it
#78
The Talk servo control doesn't do anything. The LED is just stuck at a constant dim glow.
I tried going back to Nomad's original set-up and thought maybe.... MAYBE my issue was that I was putting this code into the JavaScript instead of the EZ-Script section... but now I'm back to the dim, random blinking.
#79   — Edited
Whatever my friend
you did change the min to 1 and the max to 180?
try everything  :-)
EzAng
ezang
 for LED its min 1 to 100 max
