hi
is there a window for talk servo with led?insteadt of inmoove mouth opens, while talking,but with a led then.
Personality Generator
— Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot
hi
bobsheaux
do you have two pwm's in your project?
Nomad, in the code above, make sure you initialize : on the top
$soundright = 0
or code will not work
EzAng
hi ezang
i only changed the ports below.what means initialize ?
Here is the correct code, I did change the sleep below so it would blink faster, also I am just using D0 so I # D1 out $pwmvalue = 0 $soundright = 0
code:
Sound servo to PWM range Script
Author: Rich
Version: 1.0.0
Date: 25th June 2013
modified by EzAng August 2020
Variables (do not adjust)
$soundright = auto
Author: Rich
Version: 1.0.0
$soundright = auto
$pwmvalue = 0
Author: Rich
Version: 1.0.0
$soundright = auto
$pwmvalue = 0
Main script
Set the start point for the never ending loop
:loop
Check the variable from the Sound servo control against a list of pre-determined levels (you may need to change these) and set the PWM value to suit.
IF ($soundright < 10) $pwmvalue = 0 ELSEIF ($soundright < 20) $pwmvalue = 10 ELSEIF ($soundright < 30) $pwmvalue = 20 ELSEIF ($soundright < 40) $pwmvalue = 30 ELSEIF ($soundright < 50) $pwmvalue = 40 ELSEIF ($soundright < 60) $pwmvalue = 50 ELSEIF ($soundright < 70) $pwmvalue = 60 ELSEIF ($soundright < 80) $pwmvalue = 70 ELSEIF ($soundright < 90) $pwmvalue = 80 ELSEIF ($soundright < 100) $pwmvalue = 90 ELSE $pwmvalue = 100 ENDIF
Set the PWM with the value chosen above (you may need to change the port to suit)
# PWM(D1, $pwmvalue) PWM(D0, $pwmvalue)
Add any other PWM ports above this line with PWM(PortNo, $pwmvalue)
Sleep for 100ms to avoid saturation (you may need to adjust this to increase accuracy or increase stability. Reduce the delay for better accuracy, increase for better stability)
Sleep(1000)
You're saying "servo mic". What is "servo mic"? I see Sound servo (EZB), Sound servo (PC), Sound servo (EZB Playback), Sound servo (PC Mic), and Sound servo (PC Speaker), but I'm not seeing any "Servo Mic". I'm trying to get the LED to respond to the speech coming out of the EZB, so which of those do I use for that? You said that for the LED, all that I need is the script and the servo mic control, but then you say that I need to have the Sound PC v4 paused?
And I can't run the script. It's just giving me this:
Again, I PROMISE YOU, I'm not TRYING to be confused or argumentative here.
ezang
my script for blink is this.
pwm(d0,100) pwm(d1,100) sleep(500) pwm(d1,0) sleep(500) pwm(d1,100)
bob
its the window sound servo .
Bobsheaux it is sound servo (PC)
EzAng
