Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Sound And Servo Control Bp Talk Board
I have the BP talk board that controls the servo by sound. If I plug a headset male plug into my headphone on the PC and run it to the talk board the servo works fine but I lose the sound. Should I split the cable and run a speaker in parallel with this so I can get the sound back or does does the software have an option to not shut off the PC's speaker. Bottom line I need to hear the voice coming from computer.
I guess the other option is to leave headset port on PC along and put a mic on the talk board but I really don't want this because of background noise.
Sincerely Frank, EZ Ver 4
#33
@aliusa
I haven't set up the multiple LED's yet, but the project attached to the first post in this thread https://synthiam.com/Community/Questions/7167 uses a script to monitor the sound servo's variable and vary the PWM going to an LED when the script containing speech is run.
The sound servo EZ-B required no configuration since I am just using its variable and not actually driving a servo.
Connect an LED to port D11, run the Sound LED script, and then run the Speech Test script. Adjust Sound servo settings (speed and scaling) and scripts (port used, speech spoken, etc) as needed.
@thetechguru,
I'll give that a try tonight.
Thanks!
