Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
Servos Moving Forward
Hi Guys and and Girls,
i have got K9 responding to voice commands, including some responses from him verbally. so things are going great apart from...
when i ask him to move forward his servos respond, but only for a second (or less) and then stops, yet if i ask him to reverse his servo's keep going until i ask him to stop.
originally i thought it was due to the IR sensor interfering, so i disconnected this and repeated to test, with the same results.
any ideas?
confused
your reverse is set to repeat but your forward isnt?
Just a guess.
hi there @d.cochran,
the code looks the same
Forward() reverse()
respectfully?
@mgodsell1973 Are you using the servo movement control panel or scripts to control your robot movement?
Can you upload your forward movement script? And you said you disabled any radar control (Ping and or IR)?
HI @Richard R,
i am using the movement panel, with a script to control the speed. (both set to speed 3)
i did have a voice recognition script to play a sound bite to acknowledge the command, but in the interest of fault finding i have removed that and reverted to the two codes above when i ask KP to move forward and reverse
in the movement panel, are both set to repeat? It is a check box at the top of the list of actions.
hi @d.cochran,
i may not be looking correctly, as i cannot see a check box with this option.
can you screen shot it for me? blush
im on my cell phone right now.
Under Actions in the Auto Position Movement panel, there is a check box on the upper right side that says something like "This action repeats". See if it is checked for both the forward and reverse actions.
This is where you set your frames up to be an action.
