PWM Servo Feedback (I2c) icon PWM Servo Feedback (I2c) — Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining. Try it →
#58
Nice product...also the price tag is quiet reasonable! They might have tried to put a bit too much into the thing which makes it a kind of bulky and hard to fit into a custom build robot, but a really cool thing!
I also found something that might be worth checking out...right now you can only download a demo for Android and Windows, but lets see where they take us! Creepy how easy it gets to extract this kind of data!:D
https://www.humansensing.cs.cmu.edu/intraface/
#59
I do believe the new P2 Omron sensors are out now.
#60
Thanks for the Update...I could not ask if they would take mine and change it for the newer version until its been officially released!;)
Lets see...:)
#61
btw, if they would change it...should I go for the standard or the wide angle version?:D
#62
I personally went with the wide angle. Here are the differences:
#63
Will the current plugin David C created work with this version?
#64
Per Tony, nothing has changed other than the recording and storing of the images some. It doesn't seem possible to move any existing images and id's to the new plugins structure. The plugin should work fine but you will need to record the faces and enter the ID's (possibly with software they provide?). I assume the old software they had would also work but would be for a smaller set of faces. I haven't had time to verify this or even order a new sensor though.
