If you preordered your already then yes , you should have it between the first and second week of December. The staff are preparing shipment of the mass produced boards and kits at the present. I cannot promise when but check your order every few days. It will show shipped just a few days before receiving your order.
hi ,i just ordered the board.does the board can supply power to a camera? for excample i have one from i-qbot.got the ez cam and one from ebay whit a transmitter. confused
The camera needs to be the EZ-B v4 Camera. This is because there is a communication protocol to transmit the video. The EZ-Robot camera includes a 32 Bit ARM processor which encodes and transmits the data through the EZ-B. The camera processor is the same processor as the EZ-B.
Other cameras use their own unique interface and communication protocol. Due to no standardization across other camera modules, we had to create our own.
This is a picture of the EZ-B v4 Camera removed from the casing
This is the two camera PCB boards separated. One board includes the camera and compression chip. The other board includes the 32 bit ARM processor which buffers and communicates to the EZ-B
Here is the wire attached to the camera which connects to the EZ-B
Thanks for update on new v4 camera.
J
great.thnks dj. this is also on sale here? and how big is the camera.:)
@nomad18.08 Have a look at the online store here... It has the camera and everything else you'll need as well... And yes, the Camera is powered off of the EZB4 board...
hi i have the wireless cam from ez.but to big for what i needed for.i have a look.thx:)
I think the new V4 camera is smaller than the old V3 version....
