TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
alan i agree,more bits.
Nomad, exactly what I was describing. Thanks for the picture.
I'd love to have the ability to regulate the voltage on the VCC pins also. I really miss the 5vdv regulator we had on the V3. Adjustable voltage would be the cats A**.
I'd also like to see the EZB and ARC: *Be able to accept and use encoders for position and speed control. *Be able to set two EZB's right next to each other and have no WIFI collusion. Right now people are complaining the signals seem to cancel each other out if closer then 1 foot. I've never had this problem but others said they have and it's stopped them from using EZ Robot. *Run the EZB below 7 vdc without that annoying woman's voice nagging me that her batteries are low. I know you can disable it in ARC now but she nags at me till I connect. Reminds me of my first wife. tired
I'm afraid that if we all get our wishes though the EZB would be as big as a brick and cost as much as a car.
alan
it would be very usefull bit
Thanks for all your feedback. I will address your issues individually below. I hope this helps address the issues you have...
  1. We are unable to add more ports due to the size limitation of the ez-b and wifi speed limitation to reach our performance requirements. Each port is a physical wire that is a trace. A trace is a conductive surface embedded on a circuit board that carries electrical current. There is not enough space on the pcb to carry more traces. Additionally, we also have requirements for performance and the number of ports adheres to our wifi performance.
  2. voltage regulators will not appear on any future ez-b. This is because the most common item attached to a robot controller are servos. A servo contains a DC motor. DC Motors should never be run through a voltage regulator for a few reasons. The first reason is the waste in power consumption. The second is the danger of heat generation. The third is the limit to the number of motors you would be able to connect. And the fourth is the issue with brownouts from servo motors (As many of you have experienced in the ez-b v3). We have a solution, if you need +5v on the port. Introducing the 5v regulator, available in our store: https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=9&productNumber=98
  3. You can control the speed of any motor controller by using the motor controllers speed control interface. Usual hbridge motor controllers have a PWM or Serial interface for controlling speed. Consult your datasheet for the speed controller on what interface they use. Someone on the forum will be able to help you code against the hbridge. Natively, we support the Sabertooth and EZRobot 2.5amp motor controller. The 2.5 amp motor controller can be found here: https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=9&productNumber=14 It uses the PWM signals to control the speed. Consult the ARC manual for the PWM HBridge for more information.
  4. There is nothing we can do about WiFi interference. WiFi uses radio frequency. Radio frequencies are transmitted through the air and therefore adhere to the laws of physics. If there are reports of WiFi interference by having two radio devices too close together, this page may be of assistance: https://en.wikipedia.org/wiki/Electromagnetic_interference_at_2.4_GHz
  5. On newer EZ-B's v4s, the battery monitor can be disabled in the HTTP Server. This is not recommended for lipo battery users.
  6. Signal output pins cannot change their voltage because the signal is an output from a microcontroller. In the ez-b's case, it is an ARM. We spent months testing various microcontrollers to find one that is 5 volt tolerant input and delivers the performance required. In order to have a selectable voltage on the output signal lines for output, the PCB of the ez-b would most likely change to approx. 4-5 times the size (making it about 6x6 inches) this is because we would now need to not only determine the input/output of each I/o but also use transistors and a separate power supply to determine what voltage setting was configured. However, if you wish to output a voltage between 0 and 3.3 volts, the PWM function is available for each pin.
  7. The WiFi speed limits the use of transmitting the data of two cameras. This is another issue the physics of radio transmission:). The more distance we add, the less data bitrate is available. Additionally, one of the requirements for the ez-robot camera was to have very low latency for instant robot response. We are incredibly proud of the very low latency of the ez-robot camera. Infact, we have the lowest latency of any wifi camera that we tested against. This is also due to the wifi selection and calculations that use the wifi data bandwidth efficiently. Many months were spent testing and ensuring the lowest latency with highest distance.
  8. We will not be adding a google cardboard equivalent in ARC because attaching a laptop to your head would be funny. If you are wishing to use the Google Glasses with an Android device, you can download their software and purchase the google glasses cardboard kit. However, we will be adding oculus rift support once they have identified the issues with their sdk. There are many other third party VR hardware headsets that we will be adding support too as well, when their prices are lowered.
  9. Bluetooth is not an option for the ez-b because the bitrate is too slow. You would lose the ability to have vision and audio. Additionally, the Auto Position and other features would be limited due to the slower speed. Bluetooth is great for remote controls, audio headsets, and low power hid. You can find more about Bluetooth on Wikipedia here: https://en.wikipedia.org/wiki/Bluetooth
  10. We are unable to customize or change the size of the ez-b because it is as small as it can be. Physical circuits are not able to become smaller due to the size of their physical counterparts. Additionally, PCB's are created in factories to keep the cost down. A one-off ez-b would cost over $100 to manufacturer and therefore we would need to sell it for a higher price to return a profit margin to cover the expenses of software development. Having multiple sized (larger is the only direction we could go) ez-bs would result in a very expensive hardware cost. It would also make logistics and inventory storage very challenging for us.
  11. We have the EZ-Bit sensor add-on's on the list todo. They include Gyro's, Accelerometers, Compass and a few more. At the moment, we are focusing on selling the Revolution line of robots. Once we have sold enough to afford to manufacture and design more parts, we will.
  12. A single variable watcher can be added to the todo list for the future in ARC.
  13. If you can find a larger capacity batter that fits in JD, you can upgrade the battery. The battery we chose for JD falls within the safety requirements for shipping international and through schools, etc.. There are logistical reasons for decisions of our battery selection that include safety, shipping and inventory storage... and as well as cost to keep the product affordable. It has taken many man hours to investigate what batteries and requirements are needed for shipping. We selected LiPo batteries due to the power that they provide. However, there are very concerning legalities across countries for shipping lipo batteries, which we needed to obey. In fact, we had to purchase a certification from the battery manufacturer of our current batteries just so we can ship them to the USA.
  14. We recognize that ez-bit adapters on the power base would be a great idea. Due to the multiple tens of thousands of dollars required in cost to make that change, it will be far in the future before we can afford to do that. Help us sell more robots and we can make changes like this quicker:)
  15. We recognize that there are requests for more ez-bits. However, due to the cost to tool molds and create additional plastic components, we are limited with what we have. Molds, tooling and design of components cost upwards of $100,000 per part. Our company is much too small to afford to create additional parts at the moment. Tell your friends to buy more robots and maybe that will change:)
Hope those answers address you issue and concerns!
With all that Said @DJ I love the EZB as it stands. if no other changes were ever made this platform would stand as the best for years to come. Wish list are just what they sound like; wishes. Most of the things asked for are just ideas being bounced off the wall and not a complaint. It's very understandable why they are not on the EZB. Thanks for the explanation anyway. It's good to be heard.
Cheers and I'm looking forward what you do have in store for us in the future!
EDIT: that 5v regulaitor in the store is a neet little thing. Can you make it so it will handle 10 amps and not just 1amp? ....... Just kidding! Thanks for providing this! It's been long awaited. :)
#15
sweet, now ill finally have a use for my oculus which has been collecting dust for a good year or so;)
#16
@Dj.... I am sure I speak for all of us... Don't get us wrong we're human and as humans (and dogs too it seems) if you give us something awesome we always want more.... To be honest, I doubt you would find a single one of us unhappy with the current version of the ezb...
I plan on buying a lot more ez robot products (and not with store credits, either) even if you don't change a thing.... But, hmmmm the community by now has a little insight on how you think (I said a little, lol)... Somewhere in the back of your brain I know you gotta' be thinking about an EZB5... :)
